I am testing on an Arduino UNO. I want to use timer1 and interrupts to create various LED patterns. The LEDs may span multiple ports i.e PORTB and PORTD. I want to use a "volatile uint8_t*" pointer to store whether to toggle a pin on PORTB or PORTD i.e have the pointer store &PORTB or &POINTD. And then use it as necessary. However, once set, I cannot seem to be able to change the pointer in the loop.
Some more details:
I'm using timer1 in CTC mode (clear on compare match) and making use of both OCR1A and OCR1B interrupts.
When output compare A interrupt matches, the led is turned on and a flag is set for the main loop to change leds.
When output compare B interrupt matches, the led is turned off.
The switch statement works and the led pins can be changed i.e next_led and current_led, however, the next_port and current_port statements are ignored in the main loop.
The led pin change works when changing from case 3 to case 1 (when they are both PORTB), but when changing the next_port variable to PORTD this is completely ignored.
At the very beginning of the code, if I initialize current_port and next_port with &PORTD, then just PORTD led will light up and the main loop will not change the current_port and next_port variable to &PORTB.
I have tried using volatile uint16_t* for the next_port and current_port and that doesn't work, either.
What am I doing wrong?
int red_led = 9; //PORTB 1
int green_led = 10; //PORTB 2
int led3 = 5; //PORTD 5
volatile uint8_t current_led = 1; //port number of led
volatile uint8_t next_led = 1;
volatile uint8_t *current_port = &PORTB;
volatile uint8_t *next_port = &PORTB;
int counter = 0;
volatile int change_led_flag = 0;
volatile uint8_t led_state = 1;
uint16_t ocr1a_val = 10000-1; //determines period. 16MHz clock, Prescaler=8, 10000-1 ticks = 5ms period (200Hz)
uint16_t ocr1b_val = 9900-1; //determines duty cycle (99% for 10000 ticks)
void setup() {
pinMode(red_led, OUTPUT);
pinMode(green_led, OUTPUT);
pinMode(led3, OUTPUT);
TCCR1A = 0;
TCCR1B = 0;
//set CTC mode
TCCR1B |= (1<<WGM12);
//set OCR1A value
OCR1A = ocr1a_val;
//set OCR1B value
OCR1B = ocr1b_val;
//set pre-scaler to 8
TCCR1B |= (1 << CS11);
//enable output compare interrupts
TIMSK1 |= (1 << OCIE1A);
TIMSK1 |= (1 << OCIE1B);
sei();
void loop() {
if(change_led_flag == 1){
current_led = next_led; //set the current led to what was just turned on
current_port = next_port; //this statement doesn't do anything.
switch (led_state) {
case 1:
led_state = 2;
next_led = 2;
next_port = &PORTB; //this statement doesn't do anything
break;
case 2:
led_state = 3;
next_led = 5;
next_port = &PORTD; //this statement doesn't do anything
break;
case 3:
led_state = 1;
next_led = 1;
break;
} //end switch statement
} //end if
} //end loop()
//turn on next_led and set change_led_flag
ISR(TIMER1_COMPA_vect){
*next_port |= (1 << next_led); //turn on led
change_led_flag = 1; //set flag to update next led
//turn off current_led
ISR(TIMER1_COMPB_vect){
*current_port &= ~(1 << current_led); //turn off led
