Author Topic: Caught up between a rock (Arduino) and a hard (ARM) place.  (Read 18005 times)
Offline Roicker
  • Country: mx
Re: Caught up between a rock (Arduino) and a hard (ARM) place.
« Reply #50 on: February 16, 2016, 09:52:24 pm »
You could reuse the Tiva-C and take this embedded systems course on edX:
https://www.edx.org/course/embedded-systems-shape-world-utaustinx-ut-6-02x
The course was discussed in detail on a recent embedded.fm podcast:
http://embedded.fm/episodes/107
EDIT: Never mind, course enrollment is closed for now :(
+1 on using the Tiva C (you already have it!)
The main reason would be that you can debug it in-circuit (put breakpoints, execute line by line, look at the memory in any given time, etc) which is something you don't get with the AVR Mega unless you buy an ATMEL ICD.
I think it's a good idea to remove the libraries and do your own routines on the Arduino, but without the In-Circuit Debugger it's going to be much harder to figure out when something is not working.
I own a Tiva C and I love it, I think it's a great kit for the money, also, the tutorials are great (I already knew embedded before using it, but still).
Offline dannyf
« Reply #51 on: February 16, 2016, 10:51:03 pm »
Since you already have arduino, avrs would be a natural starting point.
Contrary to what you have been told, there isn't much difference programming an avr vs. Programming an arm. An avr is considerably simpler and much easier to get started.
The trick is to be good at C and read lots of data sheet.
Offline autobot
« Reply #52 on: February 18, 2016, 07:37:04 pm »
Something I haven't seen brought up yet was vendor lock-in. .. 95% of my code is logic and not peripheral access - so I can make that work.
If you use the mbed, you get access to variety of chips, and much easier portability .
Offline captbill
« Reply #53 on: February 19, 2016, 05:38:22 am »
Hi All,
For a while now I have been wanting to progress myself beyond Arduino and begin to learn more about microcontrollers and become more capable, I need to home my skills.
Problem is, I know Arduino and I feel I keep diving off into the deep end, I have spent quite a bit of money on devkits for microcontrollers I think may be too complex for me.
Now, I have stepped back a bit and I want to start again into microcontrollers, I feel Arduino has just kinda messed it up, making it too simple to the point I feel lazy not understanding or doing anything beyond simple Arduino 'stuff'.
I want to try get into protocols, timing and so on, controlling Switching systems (Transformer drivers) and communications and busses, get involved with motor drivers and all sorts.
The real question I have... Where should I truly start and how? Tutorials etc. I have been kidding myself into thinking 'I know all this' for too long. When I don't really.
What I have already:
TI Launchpad Tiva C Series.
A Huge pile of Arduino products (Nanos, Megas and Unos)
Cypress CY8CKIT (the USB stick one)
Freescale FRDM-KL43Z
SAM4S-EK2 Dev Board
What would you recommend I get or start with (I don't mind buying more if it is worth while...)
What tutorials can I look at.
I really appreciate any response or advice, feedback or thoughts! :)
Take a look at Astrobe :
https://youtu.be/qmSqhAG_ea0
Astrobe targets the majority of the NXP's LPCxxx series boards. Plus has a really cool RISC5 experimental FPGA core ( a 'soft processor core' much like a PicoBlaze or MicroBlaze by based upon ProjectOberon.com). Google 'Microblaze'. It is much less intimidating to work with FPGA's than you think. Very simple actually and allows you to peek at the actual wires and gates of the 'soft processor'.
Now take a look at the compiled binary size from the compile debug panel from the project in the video:
Oberon for Cortex-M3 Compiler v5.3.0
  compiling DisplayDemo
 code generated = 972 bytes, data = 0 bytes
Now give this 300 lines of code a good study and you have the ability to do CAD drawing on an MCU!! And do all this in UNDER 1 KB.
This is the core drawing library to what I believe is the same demo in the video.
The complete program, including the CAD data for this project is a mere 17KB.
MODULE LCDST756R;
   Example ARM Cortex-M3 Oberon Module
   Description:
     Sitronix ST756R LCD Controller Driver
   Target:
     mbed systems
   Tested on:
     ARM mbed Application Board with a Newhaven C12832A1Z 128 x 32 LCD display
   Reference:
     Sitronix ST756R DataSheet Ver 1.5 (10 Mar 2006).
   (c) 2013-2014 CFB Software
   http://www.astrobe.com
IMPORT Timer, MCU, ResData, SPI, SYSTEM;
CONST
  Black*   = 0;
  White*   = 1;
  MaxX* = 127;
  MaxY* = 31;
  FontWidth = 6;
  FontHeight = 8;
  Cols* = (MaxX + 1) DIV FontWidth;
  Rows* = (MaxY + 1) DIV FontHeight;
  Pages* = (MaxY + 1) DIV 8;
  A0 = {6};    (* P0.6  = mbed P8 *)
  CS = {18};   (* P0.18 = mbed P11 *)
  Reset = {8}; (* P0.8  = mbed P6 *)
TYPE
  (* Each bit represents a pixel on the screen *)
  (* Each page can be refreshed invidually *)
  BitMap = ARRAY MaxX + 1 OF SET;
  (* 6 x 8 pixels *)
  FontPattern = ARRAY FontWidth OF BYTE;
VAR
  font: ResData.Resource;
  fontPattern: FontPattern;
  (* In-memory representation of the screen *)
  bitMap0, bitMap: BitMap;
  PROCEDURE LoadFont*(name: ARRAY OF CHAR): BOOLEAN;
  BEGIN
    ResData.Open(font, name);
    RETURN ResData.Size(font) > 0
  END LoadFont;
  (* Store the font data for a character in a 2-D pixel array *)
  PROCEDURE CharToFontPattern(ch: CHAR; VAR fontPattern: FontPattern);
  VAR
    i, index: INTEGER;
  BEGIN
    IF (ORD(ch) < ORD(" ")) OR (ORD(ch) > ORD("~")) THEN ch := "." END;
    index := (ORD(ch) - ORD(" ")) * 8;
    FOR i := 0 TO FontWidth - 1 DO
      ResData.GetByte(font, index + i, fontPattern[i]);
    END
  END CharToFontPattern;
  PROCEDURE SendData(data: INTEGER);
  BEGIN
    SYSTEM.PUT(MCU.FIO0SET, A0);
    SYSTEM.PUT(MCU.FIO0CLR, CS);
    SPI.SendData(data);
    SYSTEM.PUT(MCU.FIO0SET, CS);
  END SendData;
  PROCEDURE SendCommand(data: INTEGER);
  BEGIN
    SYSTEM.PUT(MCU.FIO0CLR, A0);
    SPI.SendData(data);
  END SendCommand;
  PROCEDURE SetColumnAddr(x: INTEGER);
  CONST
    ColumnAddrLo = 000H;
    ColumnAddrHi = 010H;
  BEGIN
    SendCommand(ColumnAddrLo + x MOD 16);
    SendCommand(ColumnAddrHi + x DIV 16)
  END SetColumnAddr;
  PROCEDURE SetPageAddr(n: INTEGER);
  CONST
    PageAddrSet  = 0B0H;
  BEGIN
    SendCommand(PageAddrSet + n)
  END SetPageAddr;
  PROCEDURE* DrawDot*(colour, x, y: INTEGER);
  BEGIN
    IF (x <= MaxX) & (y <= MaxY) & (x >= 0) & (y >= 0) THEN
      IF colour = Black THEN
        bitMap[x] := bitMap[x] + {y}
      ELSE
        bitMap[x] := bitMap[x] - {y}
      END
    END
  END DrawDot;
  PROCEDURE* DrawVerticalLine*(colour: INTEGER; x, y1, y2: INTEGER);
  VAR
    yBits: SET;
  BEGIN
    IF (x >= 0) & (y1 >= 0) & (y2 >= y1) & (y2 <= MaxY) THEN
      yBits := {y1..y2};
        bitMap[x] := bitMap[x] + yBits
      ELSE
        bitMap[x] := bitMap[x] - yBits
      END
    END
  END DrawVerticalLine;
  PROCEDURE* FillRectangle*(colour, x1, y1, x2, y2: INTEGER);
  VAR
    x: INTEGER;
    yBits: SET;
  BEGIN
    IF (x >= 0) & (x2 > x1) & (x2 <= MaxX) & (y1 >= 0) & (y2 >= y1) & (y2 <= MaxY) THEN
      yBits := {y1..y2};
        FOR x := x1 TO x2 DO bitMap[x] := bitMap[x] + yBits END
      ELSE
        FOR x := x1 TO x2 DO bitMap[x] := bitMap[x] - yBits END
      END
    END
  END FillRectangle;
  PROCEDURE* DrawFontChar(fontPattern: FontPattern; col, row: INTEGER);
  VAR
    i, x, adr, fontAdr: INTEGER;
    fontData: BYTE;
  BEGIN
    ASSERT((col >= 0) & (col < Cols) & (row >= 0) & (row < Rows), 100);
    x := (col * FontWidth);
    adr := SYSTEM.ADR(bitMap[x]) + row;
    fontAdr := SYSTEM.ADR(fontPattern);
      SYSTEM.GET(fontAdr, fontData, 1);
      SYSTEM.PUT(adr, fontData, 4)
    END
  END DrawFontChar;
  PROCEDURE DrawChar*(colour: INTEGER; ch: CHAR; col, row: INTEGER);
  VAR
  BEGIN
    CharToFontPattern(ch, fontPattern);
    DrawFontChar(fontPattern, col, row)
  END DrawChar;
  PROCEDURE Refresh*();
  (* Only write the pixel columns that have changed since the last refresh *)
  VAR
    pageNo, x, adr0, adr: INTEGER;
    data0, data: BYTE;
    col: INTEGER;
  BEGIN
    FOR pageNo := 0 TO Pages - 1 DO
      SetPageAddr(pageNo);
      col := -1;
      adr0 := SYSTEM.ADR(bitMap0) + pageNo;
      adr := SYSTEM.ADR(bitMap) + pageNo;
      FOR x := 0 TO MaxX DO
        SYSTEM.GET(adr0, data0, 4);
        SYSTEM.GET(adr, data, 4);
        IF data # data0 THEN
          IF col # x THEN
            SetColumnAddr(x);
            col := x
          END;
          SendData(data);
          INC(col)
        END
      END
    END;
    bitMap0 := bitMap
  END Refresh;
  PROCEDURE* ClearScreen*(colour: INTEGER);
  VAR
    x: INTEGER;
  BEGIN
    IF colour = White THEN
        bitMap[x] := {}
      END
    ELSE
        bitMap[x] := {0..31}
      END
    END
  END ClearScreen;
  PROCEDURE* ConfigureSPI1Pins;
  VAR
    s: SET;
  BEGIN
    (* SPI1 *)
    (* Setup    SCK1, SSEL1, MISO1, MOSI1, no SSEL *)
    (* PS0 bits 15:14 12:13  17:16, 19:18 := 10B *)
    SYSTEM.GET(MCU.PINSEL0, s);
    s := s + {15, 17, 19} - {14, 16, 18};
    SYSTEM.PUT(MCU.PINSEL0, s)
  END ConfigureSPI1Pins;
  PROCEDURE* ConfigureGPIOPins;
  VAR
    s: SET;
  BEGIN
    (* P0.6, P0.8 are GPIO ports *)
    s := s - {12, 13, 16, 17};
    SYSTEM.PUT(MCU.PINSEL0, s);
    (* P0.18 is GPIO port *)
    SYSTEM.GET(MCU.PINSEL1, s);
    s := s - {4, 5};
    SYSTEM.PUT(MCU.PINSEL1, s);
    (* P0.6, 0.8 and 0.18 are outputs *)
    SYSTEM.GET(MCU.FIO0DIR, s);
    SYSTEM.PUT(MCU.FIO0DIR, s + A0 + CS + Reset)
  END ConfigureGPIOPins;
  PROCEDURE Init*;
  CONST
    nBits = 8;
  BEGIN
    SPI.Init(SPI.SPI1, nBits, ConfigureSPI1Pins);
    ConfigureGPIOPins();
    SYSTEM.PUT(MCU.FIO0CLR, Reset);
    Timer.uSecDelay(100);
    SYSTEM.PUT(MCU.FIO0SET, Reset);
    SendCommand(0AEH); (* Display off *)
    SendCommand(0A2H); (* Bias voltage *)
    SendCommand(0A0H); (* ADC Normal *)
    SendCommand(0C8H); (* COM Scan normal *)
    SendCommand(022H); (* Resistor ratio *)
    SendCommand(02FH); (* Power on *)
    SendCommand(040H); (* Display start line 0 *)
    SendCommand(081H); (* Set contrast *)
    SendCommand(017H);
    SendCommand(0A6H); (* Display normal *)
    ClearScreen(Black);
    bitMap0 := bitMap;
    ClearScreen(White);
    Refresh();
    SendCommand(0AFH); (* DisplayOn *);
  END Init;
END LCDST756R.
« Last Edit: February 19, 2016, 06:22:22 am by captbill »
