Author Topic: CC5X/CC8E C compiler-Does/has anyone used it?  (Read 1591 times)
Offline djsbTopic starter
« on: September 28, 2024, 05:27:38 pm »
I'm going to give trying to understand some CC5X compiler code a try
https://www.bknd.com/cc5x/
I'm just wondering if anyone here has used it at all? Is there any example code anywhere? The task I have eventually set myself is to understand the code used in this Sparkfun Serial LCD. This uses a PIC16F88 MCU (I wonder if this could be replaced with a more recent part, as there appears to be a lot of silicon errata documents on the 16F88).
https://www.sparkfun.com/products/retired/9395
https://ww1.microchip.com/downloads/aemDocuments/documents/MCU08/ProductDocuments/DataSheets/30487D.pdf
The firmware is under the documents tab and uses this compiler. As this LCD board is no longer available, I had the idea that maybe I could make a custom version (of the PCB using TH parts)for a standard 16 x 2 LCD. I could of course port the code to CCS C or XC8, but as the hex file is supplied, I don't want to make it too much work (and I'm a newbie C programmer, which does not help). Besides, I may want to add I2C capability as well. What are your thoughts on this compiler if you have used it? Thanks.
« Last Edit: September 28, 2024, 05:30:06 pm by djsb »
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Online SiliconWizard
Re: CC5X/CC8E C compiler-Does/has anyone used it?
« Reply #1 on: September 28, 2024, 06:48:34 pm »
I remember of it back in early 2000's. Didn't know it still existed. ;D
The following users thanked this post: djsb
Offline westfw
« Reply #2 on: September 28, 2024, 07:51:04 pm »
I also used it (slightly) way back when.  I don't remember it having any horrible problems.
IMO, that the web site still exists is a good sign.
It does seem to have some non-standard C bits that are probably useful for microcontrollers; your big challenge is whether any of them really bother you...
//Hardware port definitions
#define     RS              PORTB.4
#define     R_W             PORTB.1
#define     BL_Control      PORTA.4
#define     CLR_DISP        0b.0000.0001 //Clear display
#define     CUR_HOME        0b.0000.0010    //Move cursor home and clear screen memory
#define     CUR_RIGHT       0b.0001.0100    //Move cursor one to right
#define     CUR_LEFT        0b.0001.0000    //Move cursor one to left
Also of worry is whether it will load up the .h files provided by microchip for newer PICs (and whether it supports the newer sub-architectures.  IIRC I used on a 12F509, which has the very minimal 12bit PIC core.  Since then there are 14 and I think 16bit (I'm talking instruction width, not data width) "enhanced" PICs with some additional instructions.   cc5x may or may not support these.
« Reply #3 on: September 28, 2024, 08:18:11 pm »
Here is the list of MCU supported by CC5X
The CC5X C compiler supports all the listed devices.
The header files are also available from the download page.
Available header file list:
Device           Header file    Published
PIC10F200        10F200.H       3.2A
PIC10F202        10F202.H       3.2A
PIC10F204        10F204.H       3.2A
PIC10F206        10F206.H       3.2A
PIC10F220        10F220.H       3.2I
PIC10F222        10F222.H       3.2I
PIC10F320        10F320.H       3.5
PIC10F322        10F322.H       3.5
PIC12C508        12C508.H       3.1K
PIC12C508A       12C508A.H      3.1K
PIC12C509        12C509.H       3.1K
PIC12C509A       12C509A.H      3.1K
PIC12C671        12C671.H       3.1K
PIC12C672        12C672.H       3.1K
PIC12CE518       12CE518.H      3.1K
PIC12CE519       12CE519.H      3.1K
PIC12CE673       12CE673.H      3.1K
PIC12CE674       12CE674.H      3.1K
PIC12(L)F1501    12F1501.H      3.5A
PIC12LF1552      12F1552.H      3.5
PIC12(L)F1571    12F1571.H      3.5A
PIC12(L)F1572    12F1572.H      3.5A
PIC12(L)F1612    12F1612.H      3.5A
PIC12(L)F1822    12F1822.H      3.4H
PIC12(L)F1840    12F1840.H      3.5A
PIC12F508        12F508.H       3.2F
PIC12F509        12F509.H       3.2F
PIC12F510        12F510.H       3.2I
PIC12F519        12F519.H       3.3H
PIC12F609        12F609.H       3.4D
PIC12F615        12F615.H       3.4D
PIC12F617        12F617.H       3.4D
PIC12F629        12F629.H       3.2I
PIC12F635        12F635.H       3.4D
PIC12F675        12F675.H       3.4D
PIC12F683        12F683.H       3.4D
PIC12F752        12F752.H       3.4H
PIC12HV609       12HV609.H      3.4D
PIC12HV615       12HV615.H      3.4D
PIC12HV752       12HV752.H      3.4H
PIC14000         14000.H        3.1K
PIC16C432        16C432.H       3.1K
PIC16C433        16C433.H       3.1K
PIC16C505        16C505.H       3.1K
PIC16C52         16C52.H        3.1K
PIC16C54A        16C54.H        3.1K
PIC16C54C        16C54.H        3.1K
PIC16CR54B       16C54.H        3.1K
PIC16CR54C       16C54.H        3.1K
PIC16C54         16C54.H        3.1K
PIC16CR54A       16C54.H        3.1K
PIC16C54B        16C54.H        3.1K
PIC16C55         16C55.H        3.1K
PIC16C55A        16C55.H        3.1K
PIC16C554        16C554.H       3.1K
PIC16C556        16C556.H       3.1K
PIC16C558        16C558.H       3.1K
PIC16CR56A       16C56.H        3.1K
PIC16C56A        16C56.H        3.1K
PIC16C56         16C56.H        3.1K
PIC16CR57B       16C57.H        3.1K
PIC16C57C        16C57.H        3.1K
PIC16CR57C       16C57.H        3.1K
PIC16C57         16C57.H        3.1K
PIC16CR58B       16C58.H        3.1K
PIC16C58         16C58.H        3.1K
PIC16C58B        16C58.H        3.1K
PIC16CR58A       16C58.H        3.1K
PIC16C58A        16C58.H        3.1K
PIC16C61         16C61.H        3.1K
PIC16CR62        16C62.H        3.1K
PIC16C62         16C62.H        3.1K
PIC16C620        16C620.H       3.1K
PIC16C620A       16C620A.H      3.1K
PIC16CR620A      16C620A.H      3.1K
PIC16C621        16C621.H       3.1K
PIC16C621A       16C621A.H      3.1K
PIC16C622        16C622.H       3.1K
PIC16C622A       16C622A.H      3.1K
PIC16C62A        16C62A.H       3.1K
PIC16C62B        16C62B.H       3.1K
PIC16C63         16C63.H        3.1K
PIC16CR63        16C63.H        3.1K
PIC16C63A        16C63A.H       3.1K
PIC16C64         16C64.H        3.1K
PIC16CR64        16C64.H        3.1K
PIC16C641        16C641.H       3.1K
PIC16C642        16C642.H       3.1K
PIC16C64A        16C64A.H       3.1K
PIC16C65         16C65.H        3.1K
PIC16CR65        16C65.H        3.1K
PIC16C65A        16C65A.H       3.1K
PIC16C65B        16C65B.H       3.1K
PIC16C66         16C66.H        3.1K
PIC16C661        16C661.H       3.1K
PIC16C662        16C662.H       3.1K
PIC16C67         16C67.H        3.1K
PIC16C71         16C71.H        3.1K
PIC16C710        16C710.H       3.1K
PIC16C711        16C711.H       3.1K
PIC16C712        16C712.H       3.1K
PIC16C715        16C715.H       3.1K
PIC16C716        16C716.H       3.1K
PIC16C717        16C717.H       3.1K
PIC16C72         16C72.H        3.1K
PIC16CR72        16C72.H        3.1K
PIC16C72A        16C72A.H       3.1K
PIC16C73         16C73.H        3.1K
PIC16C73A        16C73A.H       3.1K
PIC16C73B        16C73B.H       3.1K
PIC16C74         16C74.H        3.1K
PIC16C745        16C745.H       3.1K
PIC16C74A        16C74A.H       3.1K
PIC16C74B        16C74B.H       3.1K
PIC16C76         16C76.H        3.1K
PIC16C765        16C765.H       3.1K
PIC16C77         16C77.H        3.1K
PIC16C770        16C770.H       3.1K
PIC16C771        16C771.H       3.1K
PIC16C773        16C773.H       3.1K
PIC16C774        16C774.H       3.1K
PIC16C781        16C781.H       3.1K
PIC16C782        16C782.H       3.1K
PIC16C83         16C83.H        3.1K
PIC16CR83        16C83.H        3.1K
PIC16CR84        16C84.H        3.1K
PIC16C84         16C84.H        3.1K
PIC16C923        16C923.H       3.1K
PIC16C924        16C924.H       3.1K
PIC16C925        16C925.H       3.1K
PIC16C926        16C926.H       3.1K
PIC16CE623       16CE623.H      3.1K
PIC16CE624       16CE624.H      3.1K
PIC16CE625       16CE625.H      3.1K
PIC16(L)F1454    16F1454.H      3.5A
PIC16(L)F1455    16F1455.H      3.5A
PIC16(L)F1459    16F1459.H      3.5A
PIC16(L)F1503    16F1503.H      3.5A
PIC16(L)F1507    16F1507.H      3.5A
PIC16(L)F1508    16F1508.H      3.5A
PIC16(L)F1509    16F1509.H      3.5A
PIC16(L)F1512    16F1512.H      3.5A
PIC16(L)F1513    16F1513.H      3.5A
PIC16(L)F1516    16F1516.H      3.5A
PIC16(L)F1517    16F1517.H      3.5A
PIC16(L)F1518    16F1518.H      3.5A
PIC16(L)F1519    16F1519.H      3.5A
PIC16F15213      16F15213.H     3.8
PIC16F15214      16F15214.H     3.8
PIC16F15223      16F15223.H     3.8
PIC16F15224      16F15224.H     3.8
PIC16F15225      16F15225.H     3.8
PIC16F15243      16F15243.H     3.8
PIC16F15244      16F15244.H     3.8
PIC16F15245      16F15245.H     3.8
PIC16F15254      16F15254.H     3.8A
PIC16F15255      16F15255.H     3.8A
PIC16F15256      16F15256.H     3.8A
PIC16(L)F1526    16F1526.H      3.5A
PIC16(L)F1527    16F1527.H      3.5A
PIC16F15274      16F15274.H     3.8A
PIC16F15275      16F15275.H     3.8A
PIC16F15276      16F15276.H     3.8A
PIC16(L)F15313   16F15313.H     3.6
PIC16(L)F15323   16F15323.H     3.6
PIC16(L)F15324   16F15324.H     3.6
PIC16(L)F15325   16F15325.h     3.6
PIC16(L)F15344   16F15344.H     3.6
PIC16(L)F15345   16F15345.h     3.6
PIC16(L)F15354   16F15354.h     3.5G
PIC16(L)F15355   16F15355.h     3.5G
PIC16(L)F15356   16F15356.h     3.6
PIC16(L)F15375   16F15375.h     3.6
PIC16(L)F15376   16F15376.h     3.6
PIC16(L)F15385   16F15385.h     3.6
PIC16(L)F15386   16F15386.h     3.6
PIC16LF1554      16F1554.H      3.5A
PIC16LF1559      16F1559.H      3.5A
PIC16LF1566      16F1566.h      3.5E
PIC16LF1567      16F1567.h      3.5E
PIC16(L)F1574    16F1574.H      3.5A
PIC16(L)F1575    16F1575.H      3.5A
PIC16(L)F1578    16F1578.H      3.5A
PIC16(L)F1579    16F1579.H      3.5A
PIC16(L)F1613    16F1613.H      3.5A
PIC16(L)F1614    16F1614.H      3.5A
PIC16(L)F1615    16F1615.H      3.5A
PIC16(L)F1618    16F1618.H      3.5A
PIC16(L)F1619    16F1619.H      3.5A
PIC16(L)F1703    16F1703.H      3.5A
PIC16(L)F1704    16F1704.H      3.5A
PIC16(L)F1705    16F1705.H      3.5A
PIC16(L)F1707    16F1707.H      3.5A
PIC16(L)F1708    16F1708.H      3.5A
PIC16(L)F1709    16F1709.H      3.5A
PIC16F17114      16F17114.H     3.8B
PIC16F17115      16F17115.H     3.8B
PIC16F17124      16F17124.H     3.8B
PIC16F17125      16F17125.H     3.8B
PIC16F17126      16F17126.H     3.8B
PIC16(L)F1713    16F1713.H      3.5A
PIC16F17144      16F17144.H     3.8B
PIC16F17145      16F17145.H     3.8B
PIC16F17146      16F17146.H     3.8B
PIC16F17154      16F17154.H     3.8C
PIC16F17155      16F17155.H     3.8B
PIC16F17156      16F17156.H     3.8B
PIC16(L)F1716    16F1716.H      3.5A
PIC16(L)F1717    16F1717.H      3.5A
PIC16F17174      16F17174.H     3.8B
PIC16F17175      16F17175.H     3.8B
PIC16F17176      16F17176.H     3.8B
PIC16(L)F1718    16F1718.H      3.5A
PIC16(L)F1719    16F1719.H      3.5A
PIC16(L)F1764    16F1764.H      3.5A
PIC16(L)F1765    16F1765.H      3.5A
PIC16(L)F1768    16F1768.H      3.5A
PIC16(L)F1769    16F1769.H      3.5A
PIC16(L)F1773    16F1773.h      3.5E
PIC16(L)F1776    16F1776.h      3.5E
PIC16(L)F1777    16F1777.h      3.5E
PIC16(L)F1778    16F1778.h      3.5E
PIC16(L)F1779    16F1779.h      3.5E
PIC16(L)F1782    16F1782.H      3.5A
PIC16(L)F1783    16F1783.H      3.5A
PIC16(L)F1784    16F1784.H      3.5A
PIC16(L)F1786    16F1786.H      3.5A
PIC16(L)F1787    16F1787.H      3.5A
PIC16(L)F1788    16F1788.H      3.5A
PIC16(L)F1789    16F1789.H      3.5A
PIC16F18015      16F18015.H     3.8B
PIC16F18025      16F18025.H     3.8B
PIC16F18026      16F18026.H     3.8B
PIC16F18044      16F18044.H     3.8B
PIC16F18045      16F18045.H     3.8B
PIC16F18046      16F18046.H     3.8B
PIC16F18054      16F18054.H     3.8B
PIC16F18055      16F18055.H     3.8B
PIC16F18056      16F18056.H     3.8B
PIC16F18074      16F18074.H     3.8B
PIC16F18075      16F18075.H     3.8B
PIC16F18076      16F18076.H     3.8B
PIC16F18114      16F18114.H     3.8B
PIC16F18115      16F18115.H     3.8B
PIC16F18124      16F18124.H     3.8B
PIC16F18125      16F18125.H     3.8B
PIC16F18126      16F18126.H     3.8B
PIC16F18144      16F18144.H     3.8B
PIC16F18145      16F18145.H     3.8B
PIC16F18146      16F18146.H     3.8B
PIC16F18154      16F18154.H     3.8B
PIC16F18155      16F18155.H     3.8B
PIC16F18156      16F18156.H     3.8B
PIC16F18174      16F18174.H     3.8B
PIC16F18175      16F18175.H     3.8B
PIC16F18176      16F18176.H     3.8B
PIC16(L)F1823    16F1823.H      3.4H
PIC16(L)F1824    16F1824.H      3.4E
PIC16(L)F1825    16F1825.H      3.4H
PIC16(L)F1826    16F1826.H      3.4H
PIC16(L)F1827    16F1827.H      3.4H
PIC16(L)F1828    16F1828.H      3.4E
PIC16(L)F1829    16F1829.H      3.4H
PIC16(L)F18313   16F18313.h     3.5E
PIC16(L)F18323   16F18323.h     3.5E
PIC16(L)F18324   16F18324.h     3.5E
PIC16(L)F18325   16F18325.h     3.5E
PIC16(L)F18326   16F18326.h     3.5E
PIC16(L)F18344   16F18344.h     3.5E
PIC16(L)F18345   16F18345.h     3.5E
PIC16(L)F18346   16F18346.h     3.5E
PIC16(L)F18424   16F18424.h     3.7D
PIC16(L)F18425   16F18425.h     3.7D
PIC16(L)F18426   16F18426.h     3.7
PIC16(L)F18444   16F18444.h     3.7D
PIC16(L)F18445   16F18445.h     3.7D
PIC16(L)F18446   16F18446.h     3.7
PIC16(L)F18455   16F18455.h     3.7D
PIC16(L)F18456   16F18456.h     3.7D
PIC16(L)F1847    16F1847.H      3.4H
PIC16(L)F18854   16F18854.h     3.5E
PIC16(L)F18855   16F18855.h     3.5E
PIC16(L)F18856   16F18856.h     3.6
PIC16(L)F18857   16F18857.h     3.5E
PIC16(L)F18875   16F18875.h     3.5E
PIC16(L)F18876   16F18876.h     3.6
PIC16(L)F18877   16F18877.h     3.5E
PIC16LF1902      16F1902.H      3.4H
PIC16LF1903      16F1903.H      3.4H
PIC16LF1904      16F1904.H      3.4H
PIC16LF1906      16F1906.H      3.4H
PIC16LF1907      16F1907.H      3.4H
PIC16(L)F19155   16F19155.H     3.6
PIC16(L)F19156   16F19156.H     3.6
PIC16(L)F19175   16F19175.H     3.6
PIC16(L)F19176   16F19176.H     3.6
PIC16(L)F19185   16F19185.H     3.6
PIC16(L)F19186   16F19186.H     3.6
PIC16(L)F19195   16F19195.H     3.6
PIC16(L)F19196   16F19196.H     3.6
PIC16(L)F19197   16F19197.H     3.6
PIC16(L)F1933    16F1933.H      3.4H
PIC16(L)F1934    16F1934.H      3.4H
PIC16(L)F1936    16F1936.H      3.4H
PIC16(L)F1937    16F1937.H      3.4H
PIC16(L)F1938    16F1938.H      3.4H
PIC16(L)F1939    16F1939.H      3.4H
PIC16(L)F1946    16F1946.H      3.4H
PIC16(L)F1947    16F1947.H      3.4H
PIC16F505        16F505.H       3.2A
PIC16F506        16F506.H       3.2I
PIC16F526        16F526.H       3.3H
PIC16F527        16F527.H       3.4I
PIC16F54         16F54.H        3.2A
PIC16F57         16F57.H        3.5
PIC16F570        16F570.H       3.5
PIC16F59         16F59.H        3.5
PIC16F610        16F610.H       3.4D
PIC16F616        16F616.H       3.4D
PIC16F627        16F627.H       3.1K
PIC16F627A       16F627A.H      3.4D
PIC16F628        16F628.H       3.1K
PIC16F628A       16F628A.H      3.4D
PIC16F630        16F630.H       3.4D
PIC16F631        16F631.H       3.4D
PIC16F636        16F636.H       3.4D
PIC16F639        16F639.H       3.4D
PIC16F648A       16F648A.H      3.4D
PIC16F676        16F676.H       3.4D
PIC16F677        16F677.H       3.4D
PIC16F684        16F684.H       3.4D
PIC16F685        16F685.H       3.4D
PIC16F687        16F687.H       3.4D
PIC16F688        16F688.H       3.4D
PIC16F689        16F689.H       3.4D
PIC16F690        16F690.H       3.4D
PIC16(L)F707     16F707.H       3.4D
PIC16F716        16F716.H       3.4D
PIC16F72         16F72.H        3.2I
PIC16(L)F720     16F720.H       3.4H
PIC16(L)F721     16F721.H       3.4H
PIC16(L)F722     16F722.H       3.4D
PIC16(L)F722A    16F722A.H      3.4D
PIC16(L)F723     16F723.H       3.4D
PIC16(L)F723A    16F723A.H      3.4D
PIC16(L)F724     16F724.H       3.4D
PIC16(L)F726     16F726.H       3.4D
PIC16(L)F727     16F727.H       3.4D
PIC16F73         16F73.H        3.1K
PIC16F737        16F737.H       3.2I
PIC16F74         16F74.H        3.1K
PIC16F747        16F747.H       3.2I
PIC16F753        16F753.H       3.5
PIC16F76         16F76.H        3.1K
PIC16F767        16F767.H       3.2I
PIC16F77         16F77.H        3.1K
PIC16F777        16F777.H       3.2I
PIC16F785        16F785.H       3.4D
PIC16F818        16F818.H       3.4D
PIC16F819        16F819.H       3.4D
PIC16F83         16F83.H        3.1K
PIC16F84         16F84.H        3.1K
PIC16F84A        16F84A.H       3.1K
PIC16F87         16F87.H        3.4D
PIC16F870        16F870.H       3.2I
PIC16F871        16F871.H       3.2I
PIC16F872        16F872.H       3.2I
PIC16F873        16F873.H       3.4D
PIC16F873A       16F873A.H      3.4D
PIC16F874        16F874.H       3.4D
PIC16F874A       16F874A.H      3.4D
PIC16F876        16F876.H       3.2I
PIC16F876A       16F876A.H      3.2I
PIC16F877        16F877.H       3.2I
PIC16F877A       16F877A.H      3.2I
PIC16F88         16F88.H        3.4D
PIC16F882        16F882.H       3.4D
PIC16F883        16F883.H       3.4D
PIC16F884        16F884.H       3.4D
PIC16F886        16F886.H       3.4D
PIC16F887        16F887.H       3.4D
PIC16F913        16F913.H       3.4D
PIC16F914        16F914.H       3.4D
PIC16F916        16F916.H       3.4D
PIC16F917        16F917.H       3.4D
PIC16F946        16F946.H       3.4D
PIC16HV540       16HV540.H      3.1K
PIC16HV610       16HV610.H      3.4D
PIC16HV616       16HV616.H      3.4D
PIC16HV753       16HV753.H      3.5
PIC16HV785       16HV785.H      3.4D
The current version is 3.8C
Hertfordshire, UK
Offline Howardlong
« Reply #4 on: September 28, 2024, 08:40:15 pm »
I used it too around 20-25 years ago. It was the only PIC16 C compiler with floating point, or at least one that wasn’t horrendously expensive.
I also used the PIC18 version around the same time frame. ISTR that you had to manually organise your RAM banks.
I moved to Microchip’s C18, and then was grandfathered into XC8 (based on Hi-Tech PICC & PICC18) which covers both PIC16 & PIC18, so haven’t had any need for CC5X or CC8E since.
Unless there’s a particular reason not to, XC8 is the way to go these days IMHO. Oh, and a newer PIC, although you won’t find a pin compatible one with a PIC16F88. Microchip have standardised on pinouts for PIC16 for over 15 years.
Offline iMo
  • Country: gw
« Reply #5 on: October 14, 2024, 02:16:01 pm »
Me too, also around 2000. The free version had the 32b floating point but not the 32bit integer, afaik. The cheapest paid version was not particularly cheap, btw. I can remember I put the BasicStamp's Basic into the 16F88 and added some new functions. Also all my DDS VFOs were written in it. CC5X was the most optimized C compiler for pics at that time, indeed.
