Author Topic: MSPM0L1105 gpio interrupts  (Read 908 times)
Offline oooTopic starter
« on: February 06, 2025, 07:42:11 pm »
Hello
I am struggeling with writing interrupt service routine in CCS (code composer studio) for the MSPM0L1105. I want
to generate interrupt if a GPIO is toggled basically. I am pretty sure
how it should be setup in the syscfg GUI.
The problem is that I dont
really know the syntax of how you write the interrup service routine
function (not "inside" the function but how it should be "formed").
Happy for all answers :D
// electronics guy
Offline Phoenix
Re: MSPM0L1105 gpio interrupts
« Reply #1 on: February 08, 2025, 01:29:20 am »
Offline Buxtehude
« Reply #2 on: February 08, 2025, 10:17:03 am »
In CCS 12.8.1, using ticlang compiler, in project folder I can find interrupt prototypes under Referenced Source / SysConfig / startup_mspm0l110x_ticlang.c.
GPIO0/PORTA interrupt is in INT_GROUP1 for mspm0l1105 so you must use GROUP1_IRQHandler in your code.
Additionally you must enable gpio interrupt in NVIC yourself:
//- GPIOA:
//    + Standard Output: PA26 (LED)
//    + Standard Input with internal pull-up: PA16 (BUTTON)
void GROUP1_IRQHandler(void)
    DL_GPIO_togglePins(GPIOA, OUTPUT_LED_PIN);
int main(void)
    SYSCFG_DL_init();
    NVIC_EnableIRQ(GPIOA_INT_IRQn);
    while (1)
« Reply #3 on: February 08, 2025, 02:04:40 pm »
Yes I managed to fix it thank you   ;D
