He must've had a reason.
The obvious reason would be that there are 9999999 possible combinations of extensions, and each combination takes time to build and space in the download / on the disk, so you don't want to do combinations that no one uses.
But rv32ec for CH32V003 and rv32imac_zicsr_zifencei_zba_zbb_zbkb_zbc_zbs_zcb_zcmp for RP2350 are two that there clearly is going to be demand for!
I've been thinking about making a post for this ... I don't know if people are familiar with Zcmp. I was involved with the committee designing it. I'm not entirely convinced that its a good use of silicon compared to alternatives -- and it's DEFINITELY only for simple in-order CPUs (like original 1985 Arm...) -- but as Luke implemented it in Hazard3 it would be silly not to use it as it does save quite a lot of code size.
Example:
void move(char from, char to);
void hanoi(char from, char to, char spare, int n) {
if (n != 0) {
hanoi(from, spare, to, n-1);
move(from, to);
hanoi(spare, to, from, n-1);
With Zcmp, 34 bytes of code:
hanoi:
cm.push {ra, s0-s3}, -32
cm.mvsa01 s0,s3
mv s2,a2
mv s1,a3
.L3:
beq s1,zero,.L1
addi s1,s1,-1
cm.mva01s s0,s2
mv a3,s1
mv a2,s3
call hanoi
cm.mva01s s0,s3
call move
mv a5,s0
mv s0,s2
mv s2,a5
j .L3
.L1:
cm.popret {ra, s0-s3}, 32
Without Zcmp, 62 bytes of code:
hanoi:
addi sp,sp,-32
sw s0,24(sp)
sw s1,20(sp)
sw s2,16(sp)
sw s3,12(sp)
sw ra,28(sp)
mv s0,a0
mv s3,a1
mv s2,a2
mv s1,a3
.L3:
beq s1,zero,.L1
addi s1,s1,-1
mv a1,s2
mv a0,s0
mv a3,s1
mv a2,s3
call hanoi
mv a0,s0
mv a1,s3
call move
mv a5,s0
mv s0,s2
mv s2,a5
j .L3
.L1:
lw ra,28(sp)
lw s0,24(sp)
lw s1,20(sp)
lw s2,16(sp)
lw s3,12(sp)
addi sp,sp,32
jr ra
