Author Topic: ch340g DTR pin to nRST pin of GD32F103  (Read 659 times)
Offline mclute0Topic starter
  • Somnium aut moriar!
« on: August 01, 2022, 05:10:22 am »
usb to uart bridge ch340g DTR pin to nRST pin of GD32F103 via 1kohm resistor.
does this sound like a good idea? Seems every time you connect to the serial port it resets the entire system and an app that takes DTR low to reset errors can make for a continuous reboot cycle. Take out resistor and add a reset switch?
Offline rooppoorali
  • Country: bd
Re: ch340g DTR pin to nRST pin of GD32F103
« Reply #1 on: August 02, 2022, 04:59:20 am »
The reset switch sounds the better idea to me.
