Setting the clock tree on CubeIDE is very easy. (MCU: STM32F303K8)
I am now starting programming with Keil and I do not understand how to do it. The clock configuration is in the SystemCoreClockUpdate function (it is, right?), that needs to be called if I want to update the clock config from the initial default state.
void SystemCoreClockUpdate (void)
uint32_t tmp = 0, pllmull = 0, pllsource = 0, predivfactor = 0;
/* Get SYSCLK source -------------------------------------------------------*/
tmp = RCC->CFGR & RCC_CFGR_SWS;
switch (tmp)
case RCC_CFGR_SWS_HSI: /* HSI used as system clock */
SystemCoreClock = HSI_VALUE;
break;
case RCC_CFGR_SWS_HSE: /* HSE used as system clock */
SystemCoreClock = HSE_VALUE;
break;
case RCC_CFGR_SWS_PLL: /* PLL used as system clock */
/* Get PLL clock source and multiplication factor ----------------------*/
pllmull = RCC->CFGR & RCC_CFGR_PLLMUL;
pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
pllmull = ( pllmull >> 18) + 2;
#if defined (STM32F302xE) || defined (STM32F303xE) || defined (STM32F398xx)
predivfactor = (RCC->CFGR2 & RCC_CFGR2_PREDIV) + 1;
if (pllsource == RCC_CFGR_PLLSRC_HSE_PREDIV)
/* HSE oscillator clock selected as PREDIV1 clock entry */
SystemCoreClock = (HSE_VALUE / predivfactor) * pllmull;
else
/* HSI oscillator clock selected as PREDIV1 clock entry */
SystemCoreClock = (HSI_VALUE / predivfactor) * pllmull;
#else
if (pllsource == RCC_CFGR_PLLSRC_HSI_DIV2)
/* HSI oscillator clock divided by 2 selected as PLL clock entry */
SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
else
#endif /* STM32F302xE || STM32F303xE || STM32F398xx */
break;
default: /* HSI used as system clock */
break;
/* Compute HCLK clock frequency ----------------*/
/* Get HCLK prescaler */
tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
/* HCLK clock frequency */
SystemCoreClock >>= tmp;
Here's what I understood about this function:
1. It retrives the system clock source
2. Based on that it writes it into SystemCoreClock (what is that??). The possible sources includes the PLL output
Then there are some more assigns to SystemCoreClock, but I do not understand them.
I think I first need to set some registers in order to actually set the PLL values and configure the clock tree, then calling the SystemCoreClockUpdate, and it takes care of everithing.
Said registers should be all RCC registers listed on the reference manual (RCC_CR, CC_CFGR, RCC_CIR).
Should I set these registers on the Reset_handler before calling the SystemInit function?
Sorry if this sounds trivial, but I never did this and testing the resoults of blind tests can be really hard.
