Author Topic: Cheap Bluepill, very likely it has fake STM32 right ?  (Read 79647 times)
Online Noopy
    • Richis-Lab
Re: Cheap Bluepill, very likely it has fake STM32 right ?
« Reply #175 on: April 07, 2020, 07:09:41 pm »
Today (with thanks to the GromBeestje) I have a MM32F103CBT6 for you:
https://richis-lab.de/STM32_07.htm
 :popcorn:
The following users thanked this post: BravoV, thm_w, GeorgeOfTheJungle, soFPG, techman-001
Offline GromBeestje
« Reply #176 on: April 07, 2020, 07:52:59 pm »
Keep in mind, the MM32F103 is not compatible with STM32F103. It got some different RCC registers (I haven't compared the other peripherals yet). Furthermore it has a different Device ID, such that tools designed to work with STM32F103 (eg OpenOCD) cannot flash/debug it.  It seems there is support for it in SEGGER J-Link.  There are datasheets and reference manuals available, as well as peripheral libraries.
Online Noopy
    • Richis-Lab
« Reply #177 on: April 08, 2020, 02:43:46 pm »
And one more:  BLM32F103CBT6
https://richis-lab.de/STM32_08.htm
Online Noopy
    • Richis-Lab
« Reply #178 on: April 15, 2020, 07:26:32 pm »
I already had a STM32-fake containing a CKS32:
https://richis-lab.de/STM32_04.htm
Now I know what die is inside the second STM32-fake:
https://richis-lab.de/STM32_01.htm
It´s a Hangshun HK32:
https://www.richis-lab.de/STM32_09.htm
 :popcorn:
Credits to GromBeestje
The following users thanked this post: BravoV, thm_w, GeorgeOfTheJungle, GromBeestje, soFPG, techman-001
Online Noopy
    • Richis-Lab
« Reply #179 on: April 21, 2020, 05:25:34 pm »
I have decapped a GD32VF103 but since it´s no more a real STM32-clone I have posted it here:
https://www.eevblog.com/forum/microcontrollers/risc-v-microcontrollers-from-gigadevice/msg3027160/#msg3027160
Offline GromBeestje
« Reply #180 on: April 21, 2020, 06:39:29 pm »
Thanks for the pictures Noopy.
Can I ask you something? If I understood correctly, you started decapping your first fake because you ran into some compatibility issues. What were these compatibility issues?
Online Noopy
    • Richis-Lab
« Reply #181 on: April 21, 2020, 07:10:29 pm »
No, I never worked with the STM32. I prefer analog electronics. Digital is ok but Software only if it´s absolutely necessary.  ;D
The first STM32, the bluepill-fake was sent to me by a member of the mikrocontroller.net: It came from Matthias D. (madias) who started the topic you know already. He had problems with the DMA Controller.
Offline Jul8
« Reply #182 on: April 24, 2020, 04:18:12 pm »
I've been playing around with the STM32F103 GD32F103 CS32F103 and APM32F103. I've written some code that can tell them apart.
How about the HK32F103? Would you add detection of the HK32F103 as well? :)
Online jaromir
  • Country: sk
« Reply #183 on: April 24, 2020, 07:06:50 pm »
Does anybody know the figures in the silicon art?
It looks like STM32 families do have internal nicknames. Sometimes the nicknames do "leak to public" via various documents. For example STM32F103 seems to belong to "Piranha" family, mentioned for example here http://www.farnell.com/datasheets/1443552.pdf
That may explain the artwork.
If you happen to take a look at STM32F4xx internals, you'll probably find different artwork on it , as it belongs to "Manta" family, for example https://www.mouser.com/PCN/STMicroelectronics_8451.pdf
I wonder what other aquatic animals are hiding inside STM32 devices.
The following users thanked this post: thm_w, GeorgeOfTheJungle, newbrain, Noopy
Online Noopy
    • Richis-Lab
« Reply #184 on: April 24, 2020, 08:04:23 pm »
Very interesting! Sounds reasonable!  :-+
I agree with you, I should check some other variants.  :)
I have a new fake provided by GromBeestje:
https://www.richis-lab.de/STM32_04.htm
It came with an order of CK32.
The marking is different but still bad.
In the package I found another CKS32-die.  :-/O
The following users thanked this post: thm_w, GeorgeOfTheJungle, soFPG, techman-001
Offline GromBeestje
« Reply #185 on: June 21, 2020, 02:21:32 pm »
I've added detection for the HK32F103, however, USB is not working on my HK32 board.
The following users thanked this post: Jul8
Offline profdc9
« Reply #186 on: June 23, 2020, 02:59:53 am »
In case any of you get desperate for a real STM32F103CBT6 bluepill, I designed one and I just made it so it can be populated by JLCPCB's assembly service. You can find the gerbers at:
https://github.com/profdc9/STM32surface
It uses all basic and easy to obtain parts for the parts not available from JLCPCB, for example 6 mm buttons and USB B connectors.  You can put a STM32F303CCT6 on it if you want something better.  The kicad 3D image of the PCB is below.
Also, one of the reasons I designed my own is so I could lay it out better and make it more noise immune, and the ADC definitely seems to be somewhat less noisy with this board.
Dan
« Last Edit: June 23, 2020, 03:01:57 am by profdc9 »
The following users thanked this post: thm_w, GeorgeOfTheJungle, josip, jlo, Renaud
Offline Jul8
« Reply #187 on: June 23, 2020, 09:15:30 am »
Thank you!  :)
The following users thanked this post: paf
Offline Doctorandus_P
« Reply #188 on: July 29, 2020, 11:59:44 am »
I just had a brainfart (good smelling variant) and did a search for the F103 on LCSC without the "STM", and they sell 7 different variants.
https://lcsc.com/search?q=32F103C8T6
Prefix:      Mgf:
CSK         CSK
HK         HK
APM         Apexmic
BLM         Shenzhen Better Life Elec
GD         GigaDevices
MM         MindMotion Microelectronics
ST         STMicroelectronics
The MM part was labeled as a 5V part which is very unusual for Cortex M3, but the datasheet seems to confirm it:
http://www.mindmotion.com.cn/userfiles/images/MM32F103XiLieWenDang/DS_MM32F103xx_o_V1.13_EN.pdf
For me this probably the end of buying "Blue Pill" boards from China / Ali.
In the latest batch I had to change the ID number to get them programmed at all, and a test program of GRBL for STM32 does not save it's settings in Flash.
I have no interest in figuring out the incompatibilities between those different variants, and Ali Sellers relabeling everything as "STM32" makes it impossible to know what you buy.
Quite a shame, because I liked the form factor a lot. They fit on Breadboads and on matrix board, and I used to solder in the thin round pins instead of the thick square pins, so they can be used in much lower profile sockets.
I also liked the very small ST-Link V2 programmers with Aluminum housing and pinout labeled on the outside.
I never liked the bulky Discovery boards and their on board programmers.
If some western manufacturer sold the "Blue Pill" boards for somewhere around EUR5 I would buy them.
From what I've read, LCSC should be a trustworthy seller. The STM variant is their most expensive, (and slowest, least peripherals probably) but I really don't care about that. Just that it works according to the datasheet, and you don't with those re-labled uC's on the Pills.
STM is USD 1.5 (10 up) from LCSC, while if you look at Octopart, no western seller has them below USD 4 (10 up).
Online Noopy
    • Richis-Lab
« Reply #189 on: July 29, 2020, 12:56:10 pm »
Prefix:      Mgf:
CSK         CSK
HK         HK
APM         Apexmic
GD         GigaDevices
Affirmative!
Had them all:
https://www.richis-lab.de/STM32.htm
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #190 on: July 29, 2020, 02:20:43 pm »
Any opinions on JLCPCB? Their parts library gives $1.18 for STM32F103C8T6, quantity 30, and it is a "basic part".
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #191 on: July 29, 2020, 02:33:51 pm »
I haven't bought any bluepills since 2017. Designing a PCB is so trivial that I don't fuck with arduinos or *pills anymore and simply drop a MCU into any design, even MCUs I've never used before.
If you really insist, it'd probably take 30 minutes to design a compatible blue pill PCB with passives all on the bottom side, so it can be easily assembled by JLC SMT. Then you could easily product a batch to sell.
Email: OwOwOwOwO123@outlook.com
The following users thanked this post: thinkfat
Offline profdc9
« Reply #192 on: July 30, 2020, 04:32:41 pm »
You can get my Bluepill design made at JLCPCB with SMT assembly:
This includes BOM and placement files as xlsx format.  It uses all basic parts from JLC PCB.  You can get five made for about $28.
Dan
Offline GromBeestje
« Reply #193 on: September 17, 2020, 08:19:53 pm »
You might have a look at Cypress. They used to have a  CY8CKIT-049  (PSoC 42xx series) for $4 on their website. Unfortunately they seem no longer available. But those have been around for many years. I'm kinda surprised that a board from a western manufacturer, at that price point, hasn't become popular in the hobby community.
For a slightly higher price,  $10, they still sell their CY8CKIT-043 (PSoc 42xxM series) and CY8CKIT-059 (PSoC5L series).
In Europe you can get them at RS. The -043 sells for € 8,62 and the -059 for € 13,08.
« Reply #194 on: September 19, 2020, 07:09:57 am »
I was unfamiliar with the PsoC, though I have a vague memory I heared taht letter comination sometimes.
A quick look at:
https://www.cypress.com/documentation/development-kitsboards/psoc-4-cy8ckit-049-4xxx-prototyping-kits
and it reads:
The CY8CKIT-049-42xx Prototyping kit supports the Arm® 32-bit Cortex-M0™ CY8C42xx device family with up to 32KB Flash and 4KB SRAM
The STM32F103C8T6 has 64kB Flash, 20kB RAM, and it's among the smaller parts of it's family.
On reason for choosing STM32 was a (nearly?) seamless grow path into uC's with more pins, power, and peripherals than I am ever likely to need in my uC projects.
In the last few years now I've been tinkering a little bit with the things and it took me quite a lot of hours of searching the web and experimenting to find a toolchain and development environment I'm reasonably happy with. I would have found those PsoC uC's interesting when I was doing comparisons of different uC's to get out of the limits of the small Atmel AVR's, but that was years ago.
The CY8CKIT-043 has more flash, but still Cortes M0, twice the price and comes with the attached programmer, which I want separate. I was thinking along the lines of buying 3 or 4 programmers for some redundancy, and 20 or so boards, so those other 15 attached programmers will end up in landfill somewhere.
It's for those relatively simple project where I don't want to design a PCB and have it manufactured in China, but just grab a uC board and dump it on a Matrix board for one -off projects.
« Last Edit: September 19, 2020, 07:20:02 am by Doctorandus_P »
Offline GromBeestje
« Reply #195 on: September 19, 2020, 08:42:52 pm »
The programmers are snap-off. Their firmware can be switched between KitProg and CMSIS-DAP firmware. I would separate them before using them anyways.
And if you would get the 049, use one with them, as the 049 comes with some USB-UART instead.
The Cypress PSoCs, I guess, they are good for their analog features, like a current DAC.
But their software suite only runs on Windows. That's a downside in my opinion. You need that software to generate some code to run it.
« Reply #196 on: September 21, 2020, 11:33:00 pm »
I was looking for a new uC family when I grew out of the AVR's, and decided on STM32.
It's very unlikely I will be using any other uC family in the coming 10 years or so, and as this is an STM32 thread about the Blue Pill, please keep it a bit on topic.
Offline Kjelt
« Reply #197 on: September 22, 2020, 08:02:19 am »
Anyone knows of bluepill pcbs with a lqfp64 STM32F1xx on it (also ok if fake).
I still have 10 pcs of original STs lying with 256kB flash and 48kB ram, i could just replace the uC or design own board, still weighing the choices.
Offline josip
  • Country: hr
« Reply #198 on: September 23, 2020, 08:03:59 am »
There is LPC845-BRK that is not powerful as Blue Pill M4, but for 5 euros you get CMSIS-DAP debug probe that can be used with any NXP device.
https://mcuoneclipse.com/2019/02/02/tutorial-transforming-the-nxp-lpc845-brk-into-a-cmsis-dap-debug-probe/
Offline profdc9
« Reply #199 on: September 23, 2020, 01:13:25 pm »
I made a PCB that takes STM32F405RGT6 but can also take STM32F103R types with a few component swaps:
https://github.com/profdc9/STM32F4ThruPill
The following users thanked this post: thm_w, Kjelt
