Author Topic: Cheapest VHDL learning platform  (Read 8901 times)
Offline zapta
Re: Cheapest VHDL learning platform
« Reply #25 on: December 04, 2013, 06:46:15 pm »
Just stumbled upon this one
50$ for the 50k gate version
https://www.tindie.com/products/MicroNova/mercury-dip-fpga-board/
Drain the swamp.
Online mrflibble
« Reply #26 on: December 04, 2013, 06:49:42 pm »
Ok. I decide to try Actin HDL (student edition). I made basic code. How can I test it? I can't find good tutorial on google.
You can test it by making a testbench. See this here tutorial.
Offline filip_cro
  • Country: hr
« Reply #27 on: December 04, 2013, 07:56:34 pm »
Can you give me VHDL test bench for (I called my first project test):
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity test is
    port(
        sw0 : in STD_LOGIC;
        sw1 : in STD_LOGIC;
        LED0 : out STD_LOGIC;
        LED1 : out STD_LOGIC
end test;
architecture test of test is
begin
   LED1 <= sw1;
    LED0 <= sw0;
end test;
I need some periodic signal on sw0 and sw1.
Offline Crazy Ape
« Reply #28 on: December 04, 2013, 08:04:07 pm »
First, you'll need a clock.
Offline Fantasma25
  • Country: mx
« Reply #29 on: December 04, 2013, 08:08:16 pm »
library IEEE;
entity test is
    port(
        sw0 : in STD_LOGIC;
        sw1 : in STD_LOGIC;
end test;
begin
   LED1 <= sw1;
    LED0 <= sw0;
end test;
I hope this is what you're looking for  ;)
I inserted one clock at 5MHz and another one at 10MHz.
Offline filip_cro
  • Country: hr
« Reply #30 on: December 04, 2013, 08:37:45 pm »
Thank you. Now I can test my code. For few weeks/months that will work and then I will think again about devboard.
