Author Topic: DAC  (Read 1889 times)
Offline arh8080Topic starter
  • Country: ir
DAC
« on: April 14, 2016, 05:22:32 am »
I would like to create a 16 bit DAC in STM32F103RET6. ButSTM32F103RET6 only has 12 bit DAC. How do I implement a higher resolution DAC in STM32F103RET6?
Thank you. Please see link below
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwirsPi8r43MAhUDOJoKHdXJAqoQFggoMAI&url=http%3A%2F%2Fwww.cypress.com%2Ffile%2F136326%2Fdownload&usg=AFQjCNGMTYfBJtqGyTpFVwAPRUurSabTYg&sig2=kmZVVSw8sK1GryLJgSaAhQ&bvm=bv.119408272,d.bGs
tanks mikerj I need for the following circuit
« Last Edit: April 14, 2016, 02:47:09 pm by arh8080 »
Offline mikerj
Re: DAC
« Reply #1 on: April 14, 2016, 07:17:18 am »
If it's for a DC or a very low frequency applications (e.g. a low speed control loop) then you can use a timer interrupt to dither the DAC output, and low pass filter the result.
The following users thanked this post: arh8080
