Author Topic: looking for a method to test the ram on a linux sbc  (Read 1262 times)
Offline legacy
« on: January 15, 2017, 04:11:24 pm »
so, I happen to have realized a made in home linux SBC, and I'd like to test if the ram is OK since I have manually soldered it on the PCB.
do you know, guys, a method to check how good it is?
I could implement a few lines of C (1), but before reinventing the wheel I know I'd better ask, so here I am  :D
(1) e.g. with a big malloc, and then doing pattern-check (address in address) inside the slice
may be a good idea?
Offline amyk
Re: looking for a method to test the ram on a linux sbc
« Reply #1 on: January 15, 2017, 04:20:38 pm »
You may get some ideas from http://www.memtest.org/
Offline nctnico
« Reply #2 on: January 15, 2017, 05:46:09 pm »
There is a program for Linux called 'memtester'.
Offline legacy
« Reply #3 on: January 15, 2017, 08:03:01 pm »
*  sys-apps/memtester
      Homepage:      http://pyropus.ca/software/memtester/
      Description:   userspace utility for testing the memory subsystem for faults
      License:       GPL-2
thanks  :D
Online edpalmer42
« Reply #4 on: January 15, 2017, 08:14:00 pm »
If you can boot your system from a live CD/DVD (or probably USB) of most distros, they have memtest as a boot menu option.
Offline legacy
« Reply #5 on: January 15, 2017, 09:28:00 pm »
it's neither x86 nor arm, there is no CD/DVD for it  :D
But, I can use the kernel + the rootfs to test the ram.
