I am having an issue compiling code for the STM32U575 in uVision for which it seems there should be an easy fix I am not aware of. The linker is throwing the error:
.\Objects\NVM_RevB.axf: Error: L6218E: Undefined symbol SECURE_SystemCoreClockUpdate (referred from system_stm32u5xx_ns.o).
The full output is below:
Tool Versions:
IDE-Version: µVision V5.39.0.0
Tool Versions:
Toolchain: MDK-Lite Version: 5.39.0.0
Toolchain Path: C:\Keil_v5\ARM\ARMCLANG\Bin
C Compiler: ArmClang.exe V6.21
Assembler: Armasm.exe V6.21
Linker/Locator: ArmLink.exe V6.21
Library Manager: ArmAr.exe V6.21
Hex Converter: FromElf.exe V6.21
CPU DLL:
Dialog DLL:
Target DLL: STLink\ST-LINKIII-KEIL_SWO.dll V3.2.0.0
Dialog DLL: TCM.DLL V1.56.4.0
Output:
*** Using Compiler 'V6.21', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'
Build target 'Target 1'
compiling ad403x.c...
compiling gpio.c...
compiling startup_stm32u575xx.c...
compiling ad5686.c...
compiling delay.c...
compiling uart.c...
compiling it.c...
compiling system_stm32u5xx_ns.c...
compiling dac.c...
compiling adc.c...
compiling main.c...
compiling sys_cfg.c...
compiling ospi.c...
compiling spi.c...
compiling tim.c...
linking...
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
Finished: 2 information, 0 warning and 1 error messages.
".\Objects\NVM_RevB.axf" - 1 Error(s), 0 Warning(s).
Software Packages used:
Package Vendor: ARM
[url]https://www.keil.com/pack/ARM.CMSIS.6.0.0.pack[/url]
ARM::CMSIS@6.0.0
CMSIS (Common Microcontroller Software Interface Standard)
* Component: CORE Version: 6.0.0
Package Vendor: Keil
[url]https://www.keil.com/pack/Keil.STM32U5xx_DFP.2.2.0.pack[/url]
Keil::STM32U5xx_DFP@2.2.0
STMicroelectronics STM32U5 Series Device Support
* Component: Startup Variant: Source C Version: 1.0.0
Collection of Component include folders:
./RTE/_Target_1
Collection of Component Files used:
* Component: ARM::CMSIS:CORE@6.0.0
Include file: CMSIS/Core/Include/tz_context.h
* Component: Keil::Device:Startup&Source C@1.0.0
Include file: Drivers/CMSIS/Device/ST/STM32U5xx/Include/stm32u5xx.h
Source file: MDK/Device/Source/startup_stm32u575xx.c
Source file: Drivers/CMSIS/Device/ST/STM32U5xx/Source/Templates/system_stm32u5xx_ns.c
Include file: Drivers/CMSIS/Device/ST/STM32U5xx/Include/partition_stm32u5xx.h
Target not created.
Build Time Elapsed: 00:00:01
The function SECURE_SystemCoreClockUpdate() is defined in system_stm32u5xx_s.c, but that is not added to the project with the usual device startup code you get when you select modules from the runtime environment. I have tried using both the source C and source ASM for the Device module with no difference between the two. I have also tried adding this file manually, but this turned into a bit of a wild goose chase of undefined symbols when it was time to link the object files. I am following the general procedure I have used successfully with Cortex M4 MCUs, like the STM32F446, but it seems like the ironically named TrustZone feature in M33 makes things a bit more complicated. Is there something I am missing?
