We have a DC2026C board at work that won't connect to our PCs. I tried plugging it into several different computers, but the board would not show up in the Device Manager. Arduino IDE is also unable to detect the board and can't send serial commands, and installing drivers on the computer did not make a difference. The board is not visible to macOS either. I'm pretty sure there's an issue with the device's USB port because we were able to connect to a replacement board without problems.Does anyone have an idea what might be causing this?
