Author Topic: Cortex-M7 vs ARM926EJ-S: which is more useful?  (Read 14642 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
Re: Cortex-M7 vs ARM926EJ-S: which is more useful?
« Reply #25 on: April 17, 2017, 11:55:02 pm »
Then how do I write the linker scripts to put code in ITCM? I can memcpy code over but the pointers needs to be fixed.
Offline ataradov
    • Personal site
« Reply #26 on: April 17, 2017, 11:57:33 pm »
In a linker script you specify where your code will be located (address within ITCM). This will make linker put correct addresses for that memory, but they will obviously be wrong for the flash. But that code will never be executed from flash, so it is fine.
Then, you just do memcpy(), after you set up ITCM.
Alex
  • Country: cn
    • My Untitled Blog
« Reply #27 on: April 18, 2017, 12:12:49 am »
What if the thing I want to put in ITCM is the entire program? Write a stub to copy the bulk of the code over?
Offline ataradov
    • Personal site
« Reply #28 on: April 18, 2017, 12:14:13 am »
Yes. Your startup code will have to be in flash.
Alex
  • Country: cn
    • My Untitled Blog
« Reply #29 on: April 18, 2017, 12:31:31 am »
So I basically need to create a bootloader that copies code over to ITCM and jump into it? What else should I do inside this bootloader?
Offline ataradov
    • Personal site
« Reply #30 on: April 18, 2017, 12:34:33 am »
It is not really a bootlaoder, it is your normal startup code (reset vector). It should what any other startup code does - initialize DATA and BSS segments, relocate vector table and stack pointer, and then jump to main.
Optionally, you can initialize some other hardware, but it all can be done from main().
Alex
  • Country: cn
    • My Untitled Blog
« Reply #31 on: April 18, 2017, 12:44:35 am »
My usual startup code sets up the clocks, copies data segment over to the RAM locations, zeros BSS, and calls libc _start(). Now how do I do that with ITCM involved?
Offline ataradov
    • Personal site
« Reply #32 on: April 18, 2017, 01:12:35 am »
Add ITCM initialization and in addition to data segment, copy the code. The same exact way as you do for data.
IC vendors have application notes on this. Atmel does for sure, I just don't remember the number.
Alex
