Author Topic: CS4344 (24 bit DAC)  (Read 1100 times)
Offline alizare368Topic starter
CS4344 (24 bit DAC)
« on: January 17, 2019, 09:51:13 am »
Hi
I have made some improvements to my code,here is my  new settings,
The I2S init function
static void MX_I2S2_Init(void)
  /* USER CODE BEGIN I2S2_Init 0 */
  /* USER CODE END I2S2_Init 0 */
  /* USER CODE BEGIN I2S2_Init 1 */
  /* USER CODE END I2S2_Init 1 */
  hi2s2.Instance = SPI2;
  hi2s2.Init.Mode = I2S_MODE_MASTER_TX;
  hi2s2.Init.Standard = I2S_STANDARD_PHILIPS;
  hi2s2.Init.DataFormat = I2S_DATAFORMAT_16B;
  hi2s2.Init.MCLKOutput = I2S_MCLKOUTPUT_ENABLE;
  hi2s2.Init.AudioFreq = 44100;
  hi2s2.Init.CPOL = I2S_CPOL_LOW;
  hi2s2.Init.ClockSource = I2S_CLOCK_PLL;
  hi2s2.Init.FullDuplexMode = I2S_FULLDUPLEXMODE_DISABLE;
  if (HAL_I2S_Init(&hi2s2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2S2_Init 2 */
  /* USER CODE END I2S2_Init 2 */
And this is my main function
int main(void)
  /* USER CODE BEGIN 1 */
static FRESULT  myfres=1;
uint32_t bt;
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_I2S2_Init();
  /* USER CODE BEGIN 2 */
myfres=disk_initialize(0);
myfres=f_mount(0, &fs);
myfres=f_open(&myfile, "1.wav",FA_READ);
myfres=f_read(&myfile,&sai_buf[0],sample_no,&bt);
myfres=f_read(&myfile,&sai_buf[1],sample_no,&bt);
index_buf++;
h_res=HAL_I2S_Transmit_DMA(&hi2s2,sai_buf[0],sample_no);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
if(refill)
refill=0;
myfres=f_read(&myfile,&sai_buf[index_buf%2],sample_no,&bt);
  /* USER CODE END 3 */
and this is my callback function for the I2S
void  HAL_I2S_TxCpltCallback( I2S_HandleTypeDef *  hi2s )
refill=1;
HAL_I2S_Transmit_DMA(hi2s,sai_buf[index_buf%2],sample_no);
index_buf++;
The problem is that the I2S callback would be called 8 times before comming back to main to refill the next buffer,
Do you have any Idea? I'm really in trouble and do not know what to do  |O |O |O
Online SiliconWizard
Re: CS4344 (24 bit DAC)
« Reply #1 on: January 17, 2019, 05:19:48 pm »
A couple remarks:
* Could you show the declaration of 'sai_buf'? And the value of 'sample_no'?
* I'm assuming you're doing some kind of ping-pong (double buffering), but I need to make sure you got it right.
* The "f_read(&myfile,&sai_buf[index_buf%2],sample_no,&bt)" call: have you timed how long it takes? If it takes longer than the playing of one buffer through I2S, then you're screwed and that would explain your problem.
« Reply #2 on: January 20, 2019, 01:17:16 pm »
Hi
the call back function problem has been resolved  but the audio output is not clear.
the part of the audio output is placed in the file below. :( :(  |O
