Author Topic: custom bytecode protocol, length first? Command first? Guidance?  (Read 7681 times)
Offline jnzTopic starter
Re: custom bytecode protocol, length first? Command first? Guidance?
« Reply #25 on: May 03, 2018, 09:26:11 pm »
Mostly got side tracked here because I mentioned RADIO, but that's already encapsulated. What isn't is that I'll get multiple radio packets, so while each is confirmed itself, I didn't have a way of putting them all together.
I would start with a variant of the Intel Hex Protocol:
This protocol is pretty busy so it may not be workable or it would need to be stripped down:
But, yes, there should be a record length at the beginning.  It is another question if there should be a SOF character ahead of that - Start Of Frame - or just the ':' in the Intel protocol.
rstoufer won with a link above. I modified that a serial packet protocol to be included in first radio packet, so now I have a CRC for multiple individually-confirmed packets, total length, source and dest which could be useful later.
« Last Edit: May 04, 2018, 05:11:20 am by jnz »
