Author Topic: Decent Atmel chips programmer / JTAG debugger  (Read 4340 times)
Offline miduchpTopic starter
« on: February 20, 2017, 07:38:51 pm »
Dear forum members,
I'm looking for decent programmer / JTAG debugger for Atmel chips. Most of my time I'm spending with atmega based arduino boards, but I'm also looking forward to learn xmega based chips. I'm currently using one of those cheap USBasp programmers, but I had couple of issues with them which includes:
  • problems setting up fusebits
  • random problems with programming certain chips, which at the end turns out to be caused by too long usb cable
  • lack of hardware debugging interface
  • all sorts of problems on Windows 10 with the drivers
I found this Atmel-ICE http://www.atmel.com/tools/atatmel-ice.aspx programmer, it's a bit expensive in basic version but have all I'm looking for. Does anyone have any experience with it ? Is it worth investing money or you can recommend something else ?
Thanks for your guidance in advance
Offline Frost
Re: Decent Atmel chips programmer / JTAG debugger
« Reply #1 on: February 20, 2017, 07:46:14 pm »
I use it for programming / debugging with Atmel Studio
and it works very well.
Offline ataradov
    • Personal site
« Reply #2 on: February 20, 2017, 09:52:56 pm »
Atmel-ICE is a very good tool. You can get it a bit cheaper, if you opt out for PCBA version.
Alex
Offline Dan Moos
« Reply #3 on: February 20, 2017, 10:03:25 pm »
I use an AVR Dragon. No complaints. Works well with Atmel Studio, if that's important to you. I've used both JTAG and debugWire for hardware debugging. Both work well, but if you can stick to chips that support JTAG, is worth it. debugWire is a pain in the but to switch back and forth from. With JTAG, this isn't an issue at all.
Sent from my E6830 using Tapatalk
Offline ataradov
    • Personal site
« Reply #4 on: February 20, 2017, 10:05:39 pm »
AVR Dragon is a good tool, but it has been obsoleted some time ago, so who knows how tool support will go. If you are getting a new tool, you should probably invest into something still active.
Alex
Offline Dan Moos
« Reply #5 on: February 20, 2017, 10:08:38 pm »
I suppose. Mine hasn't let me down, so I can't imagine further need of support for it. They're dang cheap used too. All things being equal though, yeah, get something current.
Offline ataradov
    • Personal site
« Reply #6 on: February 20, 2017, 10:10:50 pm »
I'm not talking about technical support, but rather support by Atmel Studio.
STK600 is still technically supported, for example, but it was broken on a few recent releases of the AS. Dragon is a bit newer, of course, but who knows.
Alex
Offline ajb
« Reply #7 on: February 21, 2017, 04:39:40 pm »
The Dragon also doesn't support some of the more recent parts at all, including the ATTiny parts that use TPI.  I haven't tried to use it in AS6 or 7, so not sure how well it's supported.  Unless you really need high voltage programming or you really want the ZIF socket capability, Atmel ICE is a better option than the Dragon these days, especially since it supports the Atmel SAM (ARM) parts.
Offline krho
  • Country: si
« Reply #8 on: February 21, 2017, 09:01:02 pm »
One more vote for atmel-ice
Offline Brutte
« Reply #9 on: February 21, 2017, 09:33:32 pm »
Are you aware that arduino IDE environment does not offer any hardware debugging? Even when you buy debugger, you won't be able to debug your sketches, afaik.
You could debug some AVR8s with other toolchains and IDEs but not with Arduino IDE.
AVR8s are dead as a Dodo. Get some ARM Cortex eval, most come with debuggers on-board.
Offline hfleming
  • Country: no
« Reply #10 on: February 21, 2017, 11:45:29 pm »
Atmel-ice and AVR studio. With avr studio 7 you can import Arduino projects too, even if it is a bit iffy.
Offline westfw
« Reply #11 on: February 22, 2017, 08:02:45 am »
Microchip is currently having a "$50 off" sale for the "full" Atmel ICE kit (after having raised prices when they bought Atmel.)
Good through the end of Feb...
http://www.microchipdirect.com/ProductSearch.aspx?Keywords=ATATMEL-ICE
Discussion here: http://www.avrfreaks.net/forum/microchipdirect-atmel-ice-sale-2017-feb
(does the ARM chips too!)
Offline MickM
« Reply #12 on: February 22, 2017, 09:43:12 pm »
Hi;
 I am working on my AVR Component Tester.
The docs for avrdude say that it can use a Pickit2 to program AVR's.
Never done it, but:
http://technostuff.blogspot.com/2014/10/using-pickit2-programmer-to-program.html
https://raw.githubusercontent.com/steve-m/avrdude/master/pickit2.c
Mick M.
Offline westfw
« Reply #13 on: February 23, 2017, 12:36:11 am »
Beware that "programming an AVR" and "debugging an AVR" are two different things.  Atmel has kept the debugging protocols proprietary, so essentially the only debuggers you can buy are from Atmel.
Also, there are about 7 different programming protocols (Parallel, HV Serial, SPI, TPI, PDI, and two version of JTAG) and at least three debugging protocols (DebugWire and two varieties of JTAG), so you have to keep a relatively close eye on what you're getting...
Offline Brutte
« Reply #14 on: February 23, 2017, 07:26:47 pm »
I could never understand why freaks buy those tools. Shameless rip-off.
As for STK600 - very bspromising marketing indeed.
