Output transistors and 0R22 resistores ok, i I measure on the TP101, 102, 103, all, about 2, 3mv. Base current limiting resistors verified (I had to change 2 because they were open). On driver board all the 7 channels are the same (measured transistors, resistors, capacitors).In protection circuit I have not yet tested the D132 and Q178
Standby transformer has the primary failed. I temporarily installed another 12VAC transformer (to allow the continuation of the tests).
...but now have another situation
I turn on the AVR on the ON / OFF button and the led standby is in red, then I press the standby button, the led turns to flashing green and after 5 seconds it turns to flashing red... But only now during this process I never hear any relay to to click (I think it should be the RLY106)
will not the Q117, Q116, D154 and D157 be responsible for starting the relay? (as referenced in the attached circuit)
Thanks again for the help I have received to try to win this personal challenge of repairing my first Denon AVR
