Something else to consider about the Toshiba transistors. They could be counterfeit. A common mistake made by counterfeiters is to fake label no-name conventional transistors with Darlington part numbers. I know, because I’ve had this happen myself. I bought the devices through a reputable distributor, too. Counterfeit semiconductors are a scourge!
By the way, when checking your transistors, be sure to use the diode test mode. A Darlington will not show the same numbers a regular bipolar transistor will. Measure a bunch of known good transistors to get familiar with the reading your particular meter gives for a diode or transistor junction. Then you can tell if something isn’t right. I wonder if those Toshibas are not Darlingtons? Just a thought.
Also, I just reread your post about testing the transistors. A Darlington will have a different reading on the BE pins. Look at the output transistors on the schematic. The B to E connection passes through *two* junctions. This will normally give you approximately twice the regular reading on your diode test. This particular transistor has a resistor across the BE junction of the power transistor section, so the reading will be a bit lower. If you get a single junction reading on BE, it isn’t a Darlington transistor.
