Author Topic: Denon AVR-2105 red light flashing  (Read 7922 times)
Offline occhio37Topic starter
  • Country: pt
« on: November 21, 2018, 10:30:36 pm »
Hello to everybody!
I recently bought a damaged Denon AVR-2105 (2005 model). Red LED blinks after a few seconds of power-on. The first thing I detected was 2 short transistors on the Front L channel (Q101FL and Q102FL). I installed new ones and it was the same. I checked the regulators 7815, 7915 and the two 7805 on the power supply, they are all ok. What do you advise to check next? Why does the AVR still fail to connect? no speakers connected (there is no possibility of a short circuit) ... Is the circuit detecting the presence of DC in the audio line? Thank you very much any help in continuing the repair  ;)
Offline MiDi
  • Country: ua
Re: Denon AVR-2105 red light flashing
« Reply #1 on: November 21, 2018, 11:16:26 pm »
Power rails checked?
Does a relay click before red blinking?
DC voltage on every speaker connectors checked?
Any loose connectors or pins?
The following users thanked this post: occhio37
Offline commongrounder
« Reply #2 on: November 22, 2018, 12:47:50 am »
Since the unit is still in protection, I would check each channel output for abnormal DC offset (more than a few millivolts). A good place to probe would be at the test points 101,104, etc. It’s possible that just replacing the output transistors wasn’t enough. Sometimes, a flameproof emitter resistor in the driver stage will open up, but not show up visually.  Compare voltage measurements at the same component positions on different channels, looking for inconsistencies. Good luck!
  • Country: pt
« Reply #3 on: November 22, 2018, 09:40:37 am »
1st thank you for quick help  ;)
I hear 2 clicks and I think they come from the RLY106 relay in the power supply section. The red LED starts blinking when the relay switches off (I think ...). Voltages at the regulators 7805 (IC103, IC104) and 7815/7819 (IC101, IC102) are present (5V, 15V and -15V). After the second click on the relay they disappear. I will make the checks indicated by you .... Thank you very much.
Offline ElecSeb
« Reply #4 on: November 22, 2018, 10:48:46 am »
Did you check R148, R149 R142 R141 all 0R22 (flameproof resistor - Metal oxide 0.22 ohm 1W)
Just a hunch, but IC201 -> pin 64 PROTECTION? -> did you follow this in the SM?
There is different protects:
  • OVER_PROTECT
  • DC_PROTECT
  • PROTECT
« Last Edit: November 22, 2018, 10:57:28 am by ElecSeb »
  • Country: pt
« Reply #5 on: November 22, 2018, 01:59:36 pm »
R148, R149 R142 R141 all ok
R108FL, R109FL, R110FL and R111FL (0R22), all broken
R106FL + R107FL (4R7) with changed  \$\Omega\$ value
I will buy this material to replace all.
ElecSeb can you explain better
"Just a hunch, but IC201 -> pin 64 PROTECTION? -> did you follow this in the SM?
OVER_PROTECT
DC_PROTECT
PROTECT"
Offline ElecSeb
« Reply #6 on: November 22, 2018, 02:42:42 pm »
CONNECTOT CP502 - OVER_PROTECT -> R115FL
OVER _PROTECT connects all channels, so check also all other channels, kinda weird that only 1 channel blew! Did you caslo check the Q101FL and Q102FL and Q104FL.
Same for FR (same numbers only with FR instead of FL)
(And if you are at it, check also for C, SR and SL)
And sometimes it is difficult to locate a protect, 9 out o 10 it is power supply circuit.
In this case it is amplifier area... (Follow the OVER_PROTECT signal comming from CP502 ;) )
« Last Edit: November 22, 2018, 02:45:47 pm by ElecSeb »
  • Country: pt
« Reply #7 on: November 22, 2018, 03:00:01 pm »
Checking the PRE AMP board e detected Q502FL, Q503FL and Q504FL broken too  >:(
Q101FL e Q102FL are new
« Last Edit: November 22, 2018, 03:25:15 pm by occhio37 »
Offline ElecSeb
« Reply #8 on: November 22, 2018, 04:58:51 pm »
How are the other channels?
Btw I missed that in your FiPo.
Good you found it so far!
Btw2. If you now know this is also completely broken, I would advice to trace it back to the CNT board (IC208A, including R247FL)
« Last Edit: November 22, 2018, 05:27:54 pm by ElecSeb »
  • Country: pt
« Reply #9 on: November 23, 2018, 11:37:33 am »
 |O
Hi! Anybody know what are te specifications of standby transformer? It has 1,8k in primary winding... :palm:
Offline mzacharias
« Reply #10 on: November 24, 2018, 01:55:01 am »
1. Output transistors.
2. Emitter resistors, .22 ohm x4
3. 4.7 ohm base current limiting resistors, one or both
4. Check transistors and resistors on driver board, associated with that channel. Especially 47 ohm and 1.2 kOhm.
5. Check parts in protection circuit which tend to get damaged with amp failures on this model, like D132, and Q178 and related parts.
Offline MiDi
  • Country: ua
« Reply #11 on: November 24, 2018, 10:41:55 am »
|O
Did you measure output voltage of standby transformer?
It is not unusual that small transformers have high primary resistance...
  • Country: pt
« Reply #12 on: November 24, 2018, 12:15:26 pm »
Output transistors and 0R22 resistores ok, i I measure on the TP101, 102, 103, all, about 2, 3mv. Base current limiting resistors verified (I had to change 2 because they were open). On driver board all the 7 channels are the same (measured transistors, resistors, capacitors).In protection circuit I have not yet tested the D132 and Q178 :(...
Standby transformer has the primary failed. I temporarily installed another 12VAC transformer (to allow the continuation of the tests).
...but now  have another situation  :-\  I turn on the AVR on the ON / OFF button and the led standby is in red, then I press the standby button, the led turns to flashing green and after 5 seconds it turns to flashing red... But only now during this process I never hear any relay to to click (I think it should be the RLY106)  :(
will not the Q117, Q116, D154 and D157 be responsible for starting the relay? (as referenced in the attached circuit)
Thanks again for the help I have received to try to win this personal challenge of repairing my first Denon AVR   :clap:
« Last Edit: November 24, 2018, 12:20:30 pm by occhio37 »
Offline mzacharias
« Reply #13 on: November 24, 2018, 01:31:03 pm »
I simply do not believe there are no bad emitter resistors on the blown channel. It's not only common - it's universal on these.
As I suggested before, the protection circuit itself is often damaged in these failures.
  • Country: pt
« Reply #14 on: November 24, 2018, 02:08:59 pm »
Yes, I detected the 4 fault resistors (0R22) of the FL channel and have already replaced them, also the R106FL and R107FL (replaced)
next step i'll check the protection circuit !!   :-+
Offline kripton2035
« Reply #15 on: November 24, 2018, 03:18:58 pm »
often if you change the output transistor without changing the blown emitter resistor, then the new transistor will blow up again.
check all the previous changed transistors, and resistors.
also you should check the output of all the 78xx 79xx regulators, often the 7815 or 7915 is dead.
« Last Edit: November 24, 2018, 03:20:40 pm by kripton2035 »
  • Country: pt
« Reply #16 on: November 24, 2018, 03:54:06 pm »
I changed the 2 transistors (Q101FL and Q102FL) first and only after the resistors but I was lucky because these two remained ok. IC101, IC102, IC103 and IC104 with the correct voltages on pin 3 (OUT)
Offline ElecSeb
« Reply #17 on: November 24, 2018, 05:01:46 pm »
Based on al above, you noticed your pre-amp was blown AND your amp was blown -> ONLY for FL?
Did you trace the damage further back? -> aka opamp I mentioned before -> reason is to know which part of the system is still OK!
I have to admit this is a pretty damaged receiver!  :-+ :box:
  • Country: pt
« Reply #18 on: November 24, 2018, 06:04:23 pm »
ElecSeb you are correct, in the beginning channel FL with output transistors in short circuit and respective preamp also and red LED flashing after and a few seconds of the first sound and relay. Replace transistors and resistors and check all others. unfortunately with the tests, measurements and the on / off the standby transformer malfunctioned in the primary (I put another provisional) and now when turning on the Denon I continue with the red LED blinking, but I no longer have the first relay to sound
I bought this AVR Denon from a friend, already damaged. It is impeccably well maintained. I would really like to repair it  |O , it would become my second here at home because I already own an AVR-1902.
  • Country: pt
« Reply #19 on: November 24, 2018, 08:17:14 pm »
I already have agin the relay RL106Y clicking !! I found an interrupted track linking resistor R186 to connector CP555, RLY_POWER (as shown in the attached photo)
Let´s  :box: again!
« Last Edit: November 24, 2018, 08:48:30 pm by occhio37 »
  • Country: pt
« Reply #20 on: November 28, 2018, 04:54:26 pm »
Hello guys! after many hours checking the protection circuits, preamplifier, power and so on  |O I came to the conclusion that Denon only accepts the original Sanken transistors. Here at a local store I bought the Toshiba brand (2SD2390 + 2SB1560). Measuring them with the  :-DMM I found different values between SK (joints BE, BC and CE). Every time I put them in the circuit, the red led flashing  :palm: . The amplifier is now running  :) without the power transistors in the FL. All other channels are ok (already verified with osciloscope). I already bought the Sanken transistors on the net, I'm waiting .....
It is very strange that the same transistor model is different between manufacturers and I verified this since I bought 2 pairs of TOSHIBA. Has anyone else already checked this ??
« Last Edit: November 28, 2018, 05:01:05 pm by occhio37 »
Offline MiDi
  • Country: ua
« Reply #21 on: November 28, 2018, 06:03:40 pm »
Hm, only really thing that could be different are build in resistors.
Check the datasheets for the differences.
I did not find a datasheet for toshiba, only for sanken - are they really labeled as you stated?
Offline ElecSeb
« Reply #22 on: November 28, 2018, 06:05:35 pm »
Are you sure there is no other failure?
Your story sounds a bit weird...
If I read all the broken stuff you found already... Did you check that the signals on the actual positions of the transistors match with what should be expected?
Furthermore, can it be that there is further-on in the board there is an error, defect relay of some sort? Which gets shorted when the transistor is put in place.
Have read before that some remove the transistor (if it is an non-important channel) to use the receiver as-is.
  • Country: pt
« Reply #23 on: November 28, 2018, 06:27:39 pm »
sooner will i put a photo of toshiba transistors
  • Country: pt
« Reply #24 on: November 28, 2018, 06:39:54 pm »
Even thought to remove a pair of transistors SB channel (L or R) that I will not use and put into operation in FL but I decided to wait for the ones I bought.
All Sanken that I measured had a 4M ohmic resistance in the BE and BC junctions (and of course, the traditional 0.65V as a diode). The Toshiba, 2.8M in the BE and around 7K in the BC. I spent money on 2 pairs of Toshiba and none worked. I'll admit, it's very strange  :-//  the same transistor has to be equally indifferent to the manufacturer.
Offline ElecSeb
« Reply #25 on: November 28, 2018, 06:51:28 pm »
What I am trying to explain, are BCE having the expected signals.
What you could do is solder the toshiba in, but leave E loose. Measure while playing if output is correct.
(put mono signal on FL and FR and compare the signal between the 2 transistors -> should be equal)
Or an other option is to place a known transistor from FR to FL and see what happens (probably it will also go in protect)
« Reply #26 on: November 28, 2018, 09:13:10 pm »
Something else to consider about the Toshiba transistors.  They could be counterfeit.  A common mistake made by counterfeiters is to fake label no-name conventional transistors with Darlington part numbers. I know, because I’ve had this happen myself. I bought the devices through a reputable distributor, too. Counterfeit semiconductors are a scourge!
By the way, when checking your transistors, be sure to use the diode test mode.  A Darlington will not show the same numbers a regular bipolar transistor will.  Measure a bunch of known good transistors to get familiar with the reading your particular meter gives for a diode or transistor junction. Then you can tell if something isn’t right. I wonder if those Toshibas are not Darlingtons? Just a thought.
Also, I just reread your post about testing the transistors.  A Darlington will have a different reading on the BE pins.  Look at the output transistors on the schematic.  The B to E connection passes through *two* junctions. This will normally give you approximately twice the regular reading on your diode test.  This particular transistor has a resistor across the BE junction of the power transistor section, so the reading will be a bit lower. If you get a single junction reading on BE, it isn’t a Darlington transistor.
« Last Edit: November 28, 2018, 09:27:56 pm by commongrounder »
  • Country: pt
« Reply #27 on: December 12, 2018, 03:30:24 pm »
Good afternoon everyone! I have already received Sanken transistors and are already mounted on the amplifier. Everything is ok, all 7 channels working in full, "DENON AVR is alive and in good health"  :-+. These Darlinghton Sanken transistors were measured (diode test) and are actually different from Toshiba (these must be counterfeited). I want to thank all the people who were helping with their tips  ;)
Offline xoom
    • E.xoom
« Reply #28 on: May 16, 2019, 09:55:37 am »
Hello. Im dealing with same beast.. FL Channel have blown output transistors.. i cut legs off to make it work with other channels.. but it still in protect mode.. i see few resistors near blowen.. should i change them to get out of protection mode or they dont needed if i leave this channel dead?
Offline xoom
    • E.xoom
« Reply #29 on: May 16, 2019, 10:13:57 am »
Oh i think i see where its going.. there is like protection indication transistors Q104FL Q104SL Q104C and so on if i cut it out it should release that line.
Already did that and its alive ;D not worth to replace parts as it already in bad condition.. was dumped in sweden and somebody took it from dump :)
Anyhow Thanks to this thread author to shed some light :) and god bless service manuals :D
Cheers.
Offline xoom
    • E.xoom
« Reply #30 on: May 16, 2019, 10:52:26 am »
Other problem how without remote to turn on Channel B for Tuner? :D
