Author Topic: Design challenge for a Prius  (Read 2634 times)
Offline andy3055
Re: Design challenge for a Prius
« Reply #25 on: March 30, 2025, 08:58:57 am »
I have a 2007 Prius. Around 2014 or so, I accidentally left the light in the trunk ON and it died. I mistook it to be a bad battery and replaced it myself.  No problems at all. I coguld leave the car for 3 weeks without using and the battery would still be ok. This 2nd battery died last year and I had to call AAA to get a battery in a hurry.  The goon that came, somehow loosened the ground connection from the body and the next day the dashboard was blank! It would still start and run. But could not turn off the engine! I panicked and took it to the dealer and g v hthey found the loose connection.  Cost me $ 226 or so! I wish I didn't use AAA. It had the same problem once more and I found that one of the harnesses near the battery had a loose or dirty connection. Just scraped all the contacts and put it back. Now for many months, it starts and runs with no issues. If the dashboard goes dark, it could also be a faulty board in there due to heat and cold we subject the car to,h in normal usage. If that happens,  you could be without a car for up to 3 to 4 weeks. These boards for the older cars are not produced anymore.  The dealer has to send it to a private party for repair and input the current milage to the replacement.  All that takes weeks. What happens mostly is that the electrolytic caps on the board dries out and need to get replaced. The milage and any other info is on a chip. Once the board is touched by the dealer, you cannot get the car back until it is fixed because of legal issues.
Offline ConnecteurTopic starter
« Reply #26 on: March 30, 2025, 12:38:44 pm »
330mA is not even close to normal. The car either has some aftermarket mod installed in it, or the car is broken. Nothing new needs to be engineered; just the car fixed.
I have addressed this issue with the dealer many times, and they insist nothing is wrong. If you keep coming back and insisting on the same thing, you get put on their naughty list.
« Reply #27 on: March 30, 2025, 12:42:44 pm »
There's no point in trying to get this fixed, I just use a battery maintainer.  I went 3 days without the battery draining, so I left it over night just to see what would happen.  The battery went dead in 19 hours since I drove it.  Unpredictable battery drain is just a feature of that car.
Offline SiliconWizard
« Reply #28 on: March 30, 2025, 01:24:47 pm »
That looks pretty bad.
Offline Siwastaja
« Reply #29 on: March 30, 2025, 01:28:40 pm »
Excellent troll thread again  :popcorn:
Offline nctnico
« Reply #30 on: March 30, 2025, 02:13:39 pm »
You also have to replace the 12V battery same as any other ICE car, ~6 years or so, whatever the service manual said.
That is the best course of action. I make it a point to fit the biggest, highest capacity (quality brand) batteries in my cars. As a result I never had issues with batteries once I replaced them. Some garages fit small & cheap crap batteries to make the garage look cheap but in the end you'll suffer.
Offline madires
  • A qualified hobbyist ;)
« Reply #31 on: March 30, 2025, 02:47:03 pm »
330 mA at one point, but it's all over the map.
The recommended way for measuring the quiescent current is to park the car and wait about half an hour for the control units to power down and enter sleep mode. The quiescent current should be < 50 mA. Some cars have a slightly higher current, but should therefore also have a larger 12V battery. With a 38 Ah battery I would expect a low quiescent current.
And yes, 12V batteries in EVs die early. Their lifespan is roughly halfed compared to a battery in a car with combustion engine. It's the most common cause for EV breakdowns.
Offline tszaboo
« Reply #32 on: March 30, 2025, 03:56:31 pm »
If you think that the car battery could die in less than 24 hours, and that's somehow normal, there is nothing we can design or say to correct the problem because it's not with the car.
The following users thanked this post: nctnico, Siwastaja
Offline Siwastaja
« Reply #33 on: March 30, 2025, 04:09:09 pm »
Maybe replace with rechargeable alkaline battery? I'm sure that will work well  ;D
The following users thanked this post: Xena E
« Reply #34 on: March 30, 2025, 04:17:10 pm »
You apparently got sidetracked by my story about parasitic drain, which is unpredictable and highly variable.  Probably due to live updates.  That's not a problem I can solve.
But that wasn't the point of my original post.  I'm looking for a way to draw some power from the hybrid battery, to activate the DC-DC converter to power the 12V system.  I want a controller which would start the car when the 12V battery is dead.  This would solve the problem of having to boost the 12V battery every time it goes dead.
Offline UnijunctionTransistor
« Reply #35 on: March 30, 2025, 07:23:31 pm »
I was intending to ask a question about the RAV4 hybrid, but will open another thread to avoid derailing this thread further.
« Reply #36 on: March 30, 2025, 07:31:16 pm »
Try to mind which thread you're responding to.
Offline bdunham7
« Reply #37 on: March 30, 2025, 07:46:49 pm »
You'd have to tap into that HV hybrid battery and unless there is a commercially available (and tested) solution I doubt anyone wants to step up and hack something in there.  Besides that you have the issue of your 12V battery being destroyed by the full discharges. Our EV was going dead on occasion and the 12V batteries were not lasting, probably due to being partially discharged repeatedly even when it didn't go all the way to zero.  The solution was to pull the fuse for the telematics module.  I would suggest that the solution to your problem would be easier to implement if you were to determine what is causing that drain and put a relay in so that it is fully disconnected when the car is turned off.  If I needed the telematics module to operate, I'd do just that.  I certainly don't need it to operate when I'm not driving the car.  If you wanted to give it some alone time after driving so that it can update or whatever, you could put a 20 minute timer (or whatever) so it stays on for a bit.
« Reply #38 on: March 30, 2025, 10:24:26 pm »
The hybrid battery is already tapped into.  The DC-DC converter is switched on when the car starts, which supplies charging power to the 12 volt system.  What I tried to explain was that I needed some sort of controller to switch on the DC-DC converter so that the car's control system can come on.  As it is, when the 12V battery falls below about 11.5V, it will not start up, and only gives you a "battery too low" type message, requiring a boost or a service call to the dealer, even though there is plenty of power in the main hybrid battery.  The objective is to get the computer system to switch on, so that the DC-DC converter can do it's job supplying charging power to the 12V system.  I can't be any clearer than that.
Where did you get the idea that my 12 V battery was being destroyed? My original battery was fine, but the dealer replaced it anyway for good will I assume.  The battery goes dead unpredictably, and I want to avoid the hassle and degradation to the battery by boosting each time it happens, and it has happened at the most unexpected times.
It should be a simple matter for the controller to sense that the 12V battery is below the threshold for starting the car, and turn on the DC-DC converter, so that the 12V system can function and charge the 12V battery.  In the extremely unlikely case that the hybrid battery is below the lower charge threshold, the controller should be prevented from engaging the hybrid battery to boost the 12V system through the converter.
Online langwadt
« Reply #39 on: March 30, 2025, 10:31:57 pm »
I can't speak for Prius, but will speculate why that might be from Tesla knowledge: some cars precharge the HV DC bus from the 12V battery before closing the contactors. It can be done via the DCDC simply by making it bidirectional and boosting 12V to 200-400V or whatever the HV bus is.
If that is the case then it's a hardware limitation, not a controls one. Pure speculation though..
I've owned several Priuses, and having a dead 12V battery is a constant worry.  Many people seem to think that charging the main hybrid battery should also keep the 12V battery charged also, but that's not true for most models.
I think Toyota could have easily solved this problem, but it was probably a marketing decision not to do so.  A service call to the dealer might be the preferred option (says the conspiracy-minded me).
not only Prius, not so long ago my dads hybrid Yaris also refused to start because of a low battery
Online Xena E
« Reply #40 on: March 31, 2025, 06:54:35 am »
Remove the inverter/ DC-DC converter assembly from the car.
The part you're after is in the lower section of the assembly.
There is a possibility that the discharge problem noted is caused by MLCCs on the DC-DC converter board.
If not, the hack that the TS wants to do can be done on that board.
You will need special service tools, and it has to be done carefully as a mistake will allow coolant to leak onto the electronics in the unit.
If you have to replace the unit upper board it will need to be reprogrammed by Toyota... so don't touch it.
When you have the converter out, come back, posting  photographs and I will tell you what you need to do for the repair and/or your hack, (not recomended)...
For cars 2017 onwards, follow this video:-
 :popcorn:
X
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #41 on: March 31, 2025, 07:39:33 am »
So to prevent this issue in a Hyundai i10 parked long term at a holiday home we've just fitted a solar panel on the trunk shelf and wired it to the permanent live of the trunk light.  :P
Nothing fancy.
If there is room for an extra small 12V battery somewhere you could also see if an Cyrix-CT can help. That way you don't have to touch any of the the HV stuff, which may cause workshops to bail if they see mods.
Online Xena E
« Reply #42 on: March 31, 2025, 08:13:38 am »
Nothing fancy.
Absolutely correct, simple solutions first.  :-+ ... however reading the thread the TS doesn't seem to want to do simple.
Toyota Auris pool car at work was randomly doing this, often dead in a few days: it was a bad door switch.
It's not the fact that these things happen, its the catch 22 situation, inconvenience, and expense that it often puts the owner.
X
Offline Siwastaja
« Reply #43 on: March 31, 2025, 09:03:38 am »
Bad door switches are likely one of the most common culprits. I have had them, nearly any car have at some point when they are aging.
I have had flat battery (in totally non-hybrid 1980's and 1990's gasoline cars) maybe ~4 times total. Reasons always being me forgetting the lights on (maybe twice), or bad door switch (maybe twice, too).
Door switch can be pretty ugly in that it works intermittently so you see the interior lights turn off, and then after you are gone the lights turn on for the whole night.
Also remember the light switch of the trunk.
Simply because a modern hybrid car is very complex piece of engineering, do not assume that the failures need to be in these complicated parts. A classic mechanical failure that has stayed the same for 50 years is still the likely culprit.
« Last Edit: March 31, 2025, 09:40:43 am by Siwastaja »
Offline cv007
« Reply #44 on: March 31, 2025, 05:36:38 pm »
You have fuse panels- while measuring parasitic current pull fuses one by one to maybe at least narrow down the culprit.  Even if finding/fixing the problem doesn't prevent the occurrence of the occasional low battery condition, or the need to find a solution to that particular problem, it at least would get you back to par with most of the other Prius owners. Maybe it will take time/patience to find, but I would think it would be time well spent to get yourself a 'normal' working Prius.
« Reply #45 on: March 31, 2025, 05:37:28 pm »
This was an unwarranted low blow. I had only attempted to show courtesy to your thread, that was all.
Chill out.
« Last Edit: March 31, 2025, 05:44:52 pm by UnijunctionTransistor »
Offline Gyro
« Reply #46 on: March 31, 2025, 09:00:56 pm »
The glove box light switch is another classic one, especially when it is loaded full of crap that distorts it slightly.
Best Regards, Chris
