Hi Everyone,
Recently, while working on a design consisting of an FPGA and an ARM A8-based processor, I came across non-standard voltage levels such as 1.5, 1.8, 2.775, 3.0, and 3.15. After reading through the datasheets and reference manual, I understood that these nominal voltage levels are part of chip design, meaning I will need to design an interface circuit using voltage level shifters. I wondered why chip designers came up with non-standard voltage values like 1.5, 2.775, or 3.15 VDC. I understand that the purpose of the 1.8 V and 3.3 V logic levels was to reduce over-chip power consumption. Does anyone know anything about this specification for chip design?
Example: The image processing unit pins on the i.Mx. processor from NXP specify 2.775V as nominal voltage rating.
Spartan-6 Vccaux pin provides the option to use 2.5V or 3.3V DC.
Thanks,
tarun172
