Creating a reusable driver for your custom LED PCB is a great approach to streamline development across multiple STM32 projects. Here’s a suggested folder/file structure and some guidance on configuring your Makefile and VSCode workspace:
Folder/File Structure
You can organize your driver in a modular way. Here’s a basic structure:
MyProject/
├── my_Driver/
│ ├── my_Driver.c
│ ├── my_Driver.h
│ └── README.md (optional, but good for documentation)
├── Src/
│ ├── main.c
│ ├── stm32f4xx_it.c
├── Inc/
│ ├── main.h
│ ├── stm32f4xx_it.h
├── Makefile
└── .vscode/
├── settings.json
├── c_cpp_properties.json
Makefile Configuration
To include your custom driver in your Makefile, you’ll need to modify a few things:
1. Include Directory: Add the path to your driver’s header file to the include directories.
C_INCLUDES += -I../my_Driver
2. Source Files: Add the path to your driver’s source file to the list of source files.
C_SOURCES += ../my_Driver/my_Driver.c
VSCode Configuration
In your .vscode/c_cpp_properties.json, you should include the path to your driver’s header file to ensure IntelliSense works correctly:
"configurations": [
"name": "STM32",
"includePath": [
"${workspaceFolder}/Inc",
"${workspaceFolder}/my_Driver",
// other include paths
// other configuration settings
// other VSCode settings
General Tips
• Relative Paths: Use relative paths in your Makefile and VSCode settings to ensure portability.
• Documentation: Document your driver’s API in the my_Driver.h or a separate README file within the my_Driver folder.
• Version Control: Consider using a version control system like Git to manage your driver code, especially if you plan to use it across multiple projects.
• Testing: Ensure your driver is thoroughly tested on the Nucleo board before integrating it with other projects.
• Portability: Make your driver as hardware-agnostic as possible, abstracting out any hardware-specific details.
By following this structure and configuration, you should be able to develop a reusable driver for your LED PCB and easily integrate it into various STM32 projects. Remember that each project might require slight adjustments in the Makefile, especially if there are different hardware configurations or additional dependencies.
