Author Topic: DFU bootloader for STM32F103??  (Read 12691 times)
Offline MatCatTopic starter
« on: January 26, 2014, 01:53:11 am »
I designed my own little dev board for the STM32F103VE7, which has an internal serial bootloader, though I wanted to put a proper DFU on it.  I tried using the Maple bootloader modified slightly however it's driver is hopelessly out of whack, and I think the DFU code on it is dated and modified.  I have been looking everywhere for a DFU bootloader that will work on this chip using standard STM32 DFU loader, but not having much luck, if anyone knows I would appreciate some help, thanks!
Offline C
Re: DFU bootloader for STM32F103??
« Reply #1 on: January 26, 2014, 04:04:05 am »
How about from ST
The page with links
http://www.st.com/web/en/catalog/tools/PF258157
Get code from above page
The Pdf from above page containing description of DFU example
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/CD00158241.pdf
C
