Author Topic: Difference between NB-IoT and Wi-Sun ?  (Read 461 times)
Offline sangar
  • Country: in
« on: October 26, 2018, 01:59:15 pm »
I am looking for the difference between NB-IoT and Wi-Sun. As of now, I had that Wi-Sun is an independent network which can be configured as Mesh network, the latency between Transmitter and Receiver is in ms, supports high data rate compared to NB-IoT and we can have our control as it is the local network. For NB-IoT, the cellular base station used as a hub to establish communication between Transmitter and Receiver, latency will be in seconds, supports BPSK and QPSK modulation as per 3GPP release 13 & 14, have very low data rate.
Could you suggest if anything is there?
Thanks,
Muthu
