Author Topic: Op amp in MCU ?  (Read 2579 times)
Offline Jan AudioTopic starter
Op amp in MCU ?
« on: January 19, 2019, 04:25:38 pm »
What is the op amp in microcontrollers ?
I have the PIC16F1704 : http://ww1.microchip.com/downloads/en/DeviceDoc/40001715D.pdf
This chip has also a DAC, wich i buffer in external opamp.
I heard i can not use the op amp to buffer the DAC.
What is the opamp for then ?
Online cv007
Re: Op amp in MCU ?
« Reply #1 on: January 19, 2019, 04:48:31 pm »
The datasheet says the op amp can select the dac_output for the non-inverting input. I would assume if the dac chapter does not mention the internal op amp, its because it was copy/pasted into the datasheet from some other device that has no internal op amp (most do not). You have the chip, so try it- either the op amp chapter is wrong and you cannot select dac_output as it claims, or it works as advertised.
You have the input/output pins available, so can do 'op amp things'. With 2 of them, you get twice the fun.
Re: Op amp in MCU ?
« Reply #2 on: January 19, 2019, 05:16:01 pm »
Thanks, will try, lets see if its as fast as the best/fastest opamp i have.
Offline Flenser
Re: Op amp in MCU ?
« Reply #3 on: January 20, 2019, 05:08:35 am »
TABLE 32-17 in the datasheet lists the specs for the opamp
Re: Op amp in MCU ?
« Reply #4 on: January 20, 2019, 05:55:42 pm »
Ah, to bad its slower, the opamp i got has slew rate of 7, this one 3.
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
Re: Op amp in MCU ?
« Reply #5 on: January 24, 2019, 07:50:46 am »
There is no point using a faster opamp for a slow DAC though. And you can always use external wiring shorting some MCU pins together to chain the DAC to internal opamp.
Re: Op amp in MCU ?
« Reply #6 on: January 24, 2019, 03:27:34 pm »
Ok, i thought the DAC is as fast as the opamp ?
