Author Topic: Do ALL 20 pin PIC MCU's have the same power supply pins?  (Read 614 times)
Offline djsbTopic starter
« on: June 07, 2024, 04:30:30 am »
I'm just wondering if ALL PIC microcontrollers in the 20 pin DIP package have the same power supply pins? Anyone know? Thanks.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline hans
Re: Do ALL 20 pin PIC MCU's have the same power supply pins?
« Reply #1 on: June 07, 2024, 07:22:58 am »
No.
E.g. compare a classic PIC16F628 in SSOP-20 to a PIC24FV32KA302 in SSOP-20. Not the same.
And then a PIC16F1509 is different again.
Online Ian.M
« Reply #2 on: June 07, 2024, 07:55:51 am »
PIC16F628 in DIP is 18 pin, not 20 pin.  However Microchip chose not to do a SOIC-18, but instead doubled up the centrally located power and ground pins and put it in the SOIC-20 package.
Offline hexreader
« Reply #3 on: June 07, 2024, 11:32:16 am »
I would say that this is probably true for PIC16 and PIC18
Cannot be 100% sure, but I know of no exception.
Don't know whether any PIC12 comes in 20 pin DIP package. If there is one, then it would probably match pic16/18
PIC24 and PIC33 have very different power pins
(side note: Most, possibly all, PIC12F/16F/18F processors in DIP8 and DIP14 packages are compatible with a 20 pin DIP socket - be sure pin 1 of PIC always matches socket pin 1)
EDIT: Probably should have specified PIC16F and PIC18F above. Forgot that C versions used to exist until jpanhalt reminded me in following post.
« Last Edit: June 07, 2024, 12:42:13 pm by hexreader »
Offline jpanhalt
« Reply #4 on: June 07, 2024, 12:12:59 pm »
I agree, all 20-pin DIP for PIC16 are likely to be the same, unless you go way back to a 16C62x series, for example.
https://ww1.microchip.com/downloads/aemDocuments/documents/MCU08/ProductDocuments/DataSheets/30235j.pdf
However, since you should have the datasheet for any chip with which you are not familiar, it's easy and important to check.
The following users thanked this post: hexreader
