It means you have some stuff that really needs to be done at a specific time.
What happens when you want some stuff to be done while your processor is polling the switch?
Use a higher level interrupt! But still a microcontroller has only time to do X in Y time. So the amount of processing time to do all tasks should always be less. Using interrupts and DMA can be really helpfull but you have to plan resources usage in advance.
