And in OpenOCD I now have this when talking SWD:
$ openocd -d3 -f interface/cmsis-dap.cfg -c "transport select swd" -c "adapter speed 1000" -f target/stm32f1x.cfg
Open On-Chip Debugger 0.11.0
Licensed under GNU GPL v2
For bug reports, read
[url]http://openocd.org/doc/doxygen/bugs.html[/url]
User : 13 1 options.c:63 configuration_output_handler(): debug_level: 3
User : 14 1 options.c:63 configuration_output_handler():
Debug: 15 1 options.c:244 add_default_dirs(): bindir=/usr/local/Cellar/open-ocd/0.11.0/bin
Debug: 16 1 options.c:245 add_default_dirs(): pkgdatadir=/usr/local/Cellar/open-ocd/0.11.0/share/openocd
Debug: 17 1 options.c:246 add_default_dirs(): exepath=/usr/local/Cellar/open-ocd/0.11.0/bin
Debug: 18 1 options.c:247 add_default_dirs(): bin2data=../share/openocd
Debug: 19 1 configuration.c:42 add_script_search_dir(): adding /Users/technix/Library/Preferences/org.openocd
Debug: 20 1 configuration.c:42 add_script_search_dir(): adding /Users/technix/.config/openocd
Debug: 21 1 configuration.c:42 add_script_search_dir(): adding /Users/technix/.openocd
Debug: 22 1 configuration.c:42 add_script_search_dir(): adding /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/site
Debug: 23 1 configuration.c:42 add_script_search_dir(): adding /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/scripts
Debug: 24 1 configuration.c:97 find_file(): found /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/scripts/interface/cmsis-dap.cfg
Debug: 25 2 command.c:146 script_debug(): command - adapter driver cmsis-dap
Debug: 27 2 command.c:146 script_debug(): command - transport select swd
User : 28 2 options.c:63 configuration_output_handler(): swdUser : 29 2 options.c:63 configuration_output_handler():
Debug: 30 2 command.c:146 script_debug(): command - adapter speed 1000
Debug: 32 2 core.c:1822 jtag_config_khz(): handle jtag khz
Debug: 33 2 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 34 2 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
User : 35 2 options.c:63 configuration_output_handler(): adapter speed: 1000 kHz
User : 36 2 options.c:63 configuration_output_handler():
Debug: 37 2 configuration.c:97 find_file(): found /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/scripts/target/stm32f1x.cfg
Debug: 38 2 configuration.c:97 find_file(): found /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/scripts/target/swj-dp.tcl
Debug: 39 2 command.c:146 script_debug(): command - transport select
Debug: 40 3 configuration.c:97 find_file(): found /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/scripts/mem_helper.tcl
Debug: 41 3 command.c:146 script_debug(): command - add_usage_text mrw address
Debug: 43 3 command.c:1115 help_add_command(): added 'mrw' help text
Debug: 44 3 command.c:146 script_debug(): command - add_help_text mrw Returns value of word in memory.
Debug: 46 3 command.c:1128 help_add_command(): added 'mrw' help text
Debug: 47 3 command.c:146 script_debug(): command - add_usage_text mrh address
Debug: 49 3 command.c:1115 help_add_command(): added 'mrh' help text
Debug: 50 3 command.c:146 script_debug(): command - add_help_text mrh Returns value of halfword in memory.
Debug: 52 3 command.c:1128 help_add_command(): added 'mrh' help text
Debug: 53 3 command.c:146 script_debug(): command - add_usage_text mrb address
Debug: 55 3 command.c:1115 help_add_command(): added 'mrb' help text
Debug: 56 3 command.c:146 script_debug(): command - add_help_text mrb Returns value of byte in memory.
Debug: 58 3 command.c:1128 help_add_command(): added 'mrb' help text
Debug: 59 3 command.c:146 script_debug(): command - add_usage_text mmw address setbits clearbits
Debug: 61 3 command.c:1115 help_add_command(): added 'mmw' help text
Debug: 62 3 command.c:146 script_debug(): command - add_help_text mmw Modify word in memory. new_val = (old_val & ~clearbits) | setbits;
Debug: 64 3 command.c:1128 help_add_command(): added 'mmw' help text
Debug: 65 3 command.c:146 script_debug(): command - transport select
Debug: 66 3 command.c:146 script_debug(): command - transport select
Debug: 67 3 command.c:146 script_debug(): command - transport select
Debug: 68 3 command.c:146 script_debug(): command - swd newdap stm32f1x cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x1ba01477
Debug: 69 3 tcl.c:572 jim_newtap_cmd(): Creating New Tap, Chip: stm32f1x, Tap: cpu, Dotted: stm32f1x.cpu, 8 params
Debug: 70 3 core.c:1488 jtag_tap_init(): Created Tap: stm32f1x.cpu @ abs position 0, irlen 0, capture: 0x0 mask: 0x0
Debug: 71 3 command.c:146 script_debug(): command - dap create stm32f1x.dap -chain-position stm32f1x.cpu
Debug: 72 3 command.c:146 script_debug(): command - transport select
Debug: 73 3 command.c:146 script_debug(): command - target create stm32f1x.cpu cortex_m -endian little -dap stm32f1x.dap
Debug: 74 3 command.c:376 register_command(): command 'rtt' is already registered in '<global>' context
Debug: 75 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -work-area-phys 0x20000000 -work-area-size 0x1000 -work-area-backup 0
Debug: 76 3 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 77 3 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 78 3 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 79 3 command.c:146 script_debug(): command - flash bank stm32f1x.flash stm32f1x 0x08000000 0 0 0 stm32f1x.cpu
Debug: 81 3 tcl.c:1319 handle_flash_bank_command(): 'stm32f1x' driver usage field missing
Debug: 82 3 command.c:146 script_debug(): command - adapter speed 1000
Debug: 84 3 core.c:1822 jtag_config_khz(): handle jtag khz
Debug: 85 3 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 86 3 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 87 3 command.c:146 script_debug(): command - adapter srst delay 100
Debug: 89 3 command.c:146 script_debug(): command - transport select
Debug: 90 3 command.c:146 script_debug(): command - reset_config srst_nogate
Debug: 92 3 command.c:146 script_debug(): command - transport select
Debug: 93 3 command.c:146 script_debug(): command - cortex_m reset_config sysresetreq
Debug: 95 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event examine-end
# DBGMCU_CR |= DBG_WWDG_STOP | DBG_IWDG_STOP |
# DBG_STANDBY | DBG_STOP | DBG_SLEEP
mmw 0xE0042004 0x00000307 0
Debug: 96 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event trace-config
# Set TRACE_IOEN; TRACE_MODE is set to async; when using sync
# change this value accordingly to configure trace pins
# assignment
mmw 0xE0042004 0x00000020 0
Info : 97 3 server.c:312 add_service(): Listening on port 6666 for tcl connections
Info : 98 3 server.c:312 add_service(): Listening on port 4444 for telnet connections
Debug: 99 3 command.c:146 script_debug(): command - init
Debug: 101 3 command.c:146 script_debug(): command - target init
Debug: 103 3 command.c:146 script_debug(): command - target names
Debug: 104 3 command.c:146 script_debug(): command - stm32f1x.cpu cget -event gdb-flash-erase-start
Debug: 105 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event gdb-flash-erase-start reset init
Debug: 106 3 command.c:146 script_debug(): command - stm32f1x.cpu cget -event gdb-flash-write-end
Debug: 107 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event gdb-flash-write-end reset halt
Debug: 108 3 command.c:146 script_debug(): command - stm32f1x.cpu cget -event gdb-attach
Debug: 109 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event gdb-attach halt 1000
Debug: 110 3 target.c:1639 handle_target_init_command(): Initializing targets...
Debug: 111 3 semihosting_common.c:99 semihosting_common_init():
Debug: 112 17 cmsis_dap_usb_bulk.c:157 cmsis_dap_usb_open(): found product string of 0x0002:0xda42 'SushiBits One with CMSIS-DAP'
Debug: 113 17 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0002:0xda42
Debug: 114 17 cmsis_dap_usb_bulk.c:237 cmsis_dap_usb_open(): skipping interface 0, has only 1 endpoints
Debug: 115 17 cmsis_dap_usb_bulk.c:285 cmsis_dap_usb_open(): skipping interface 1, class 10 subclass 0 protocol 0
Debug: 116 17 cmsis_dap_usb_bulk.c:224 cmsis_dap_usb_open(): found interface 2 string 'SushiBits One Embedded CMSIS-DAP'
Debug: 117 17 cmsis_dap_usb_bulk.c:244 cmsis_dap_usb_open(): skipping interface 2, endpoint[0] is not bulk out
Debug: 118 18 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1a40:0x0101
Debug: 119 18 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1366:0x0101
Debug: 120 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x046d:0xc52b
Debug: 121 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x03f0:0x052a
Debug: 122 20 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x04d8:0x9012
Debug: 123 20 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x03eb:0x2104
Debug: 124 20 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0002:0xf003
Debug: 125 21 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0451:0x8140
Debug: 126 21 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1050:0x0407
Debug: 127 21 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x2109:0x2812
Debug: 128 22 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x046d:0x085c
Debug: 129 22 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x2109:0x2812
Debug: 130 22 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1a86:0x752d
Debug: 131 22 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0451:0x8142
Debug: 132 23 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1a40:0x0101
Info : 133 32 cmsis_dap.c:788 cmsis_dap_get_caps_info(): CMSIS-DAP: SWD Supported
Info : 134 32 cmsis_dap.c:790 cmsis_dap_get_caps_info(): CMSIS-DAP: JTAG Supported
Info : 135 34 cmsis_dap.c:768 cmsis_dap_get_version_info(): CMSIS-DAP: FW Version = 1.0
Info : 136 38 cmsis_dap.c:881 cmsis_dap_swd_open(): CMSIS-DAP: Interface Initialised (SWD)
Debug: 137 40 cmsis_dap.c:953 cmsis_dap_init(): CMSIS-DAP: Packet Size = 64
Debug: 138 42 cmsis_dap.c:966 cmsis_dap_init(): CMSIS-DAP: Packet Count = 8
Debug: 139 42 cmsis_dap.c:969 cmsis_dap_init(): Allocating FIFO for 3 pending packets
Info : 140 44 cmsis_dap.c:809 cmsis_dap_get_status(): SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 1 nRESET = 1
Info : 141 54 cmsis_dap.c:1023 cmsis_dap_init(): CMSIS-DAP: Interface ready
Debug: 142 54 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 143 54 core.c:1789 adapter_khz_to_speed(): have interface set up
Debug: 144 56 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 145 56 core.c:1789 adapter_khz_to_speed(): have interface set up
Info : 146 56 core.c:1565 adapter_init(): clock speed 1000 kHz
Debug: 147 56 openocd.c:143 handle_init_command(): Debug Adapter init complete
Debug: 148 56 command.c:146 script_debug(): command - transport init
Debug: 150 56 transport.c:229 handle_transport_init(): handle_transport_init
Debug: 151 56 command.c:146 script_debug(): command - dap init
Debug: 153 56 arm_dap.c:106 dap_init_all(): Initializing all DAPs ...
Debug: 154 60 cmsis_dap.c:843 cmsis_dap_swd_switch_seq(): JTAG-to-SWD
Info : 155 68 adi_v5_swd.c:148 swd_connect(): SWD DPIDR 0x1ba01477
Debug: 156 71 arm_adi_v5.c:653 dap_dp_init(): stm32f1x.dap
Debug: 157 71 arm_adi_v5.c:685 dap_dp_init(): DAP: wait CDBGPWRUPACK
Debug: 158 71 arm_adi_v5.h:507 dap_dp_poll_register(): DAP: poll 4, mask 0x20000000, value 0x20000000
Debug: 159 74 arm_adi_v5.c:693 dap_dp_init(): DAP: wait CSYSPWRUPACK
Debug: 160 74 arm_adi_v5.h:507 dap_dp_poll_register(): DAP: poll 4, mask 0x80000000, value 0x80000000
Debug: 161 77 cmsis_dap.c:587 cmsis_dap_swd_write_from_queue(): refusing to enable sticky overrun detection
Debug: 162 80 openocd.c:160 handle_init_command(): Examining targets...
Debug: 163 80 target.c:1827 target_call_event_callbacks(): target event 19 (examine-start) for core stm32f1x.cpu
Debug: 164 83 arm_adi_v5.c:904 dap_find_ap(): Found AHB3-AP at AP index: 0 (IDR=0x14770011)
Debug: 165 87 arm_adi_v5.c:793 mem_ap_init(): MEM_AP Packed Transfers: enabled
Debug: 166 87 arm_adi_v5.c:804 mem_ap_init(): MEM_AP CFG: large data 0, long address 0, big-endian 0
Debug: 167 90 target.c:2589 target_read_u32(): address: 0xe000ed00, value: 0x411fc231
Debug: 168 90 cortex_m.c:2001 cortex_m_examine(): Cortex-M3 r1p1 processor detected
Debug: 169 90 cortex_m.c:2012 cortex_m_examine(): cpuid: 0x411fc231
Debug: 170 93 target.c:2589 target_read_u32(): address: 0xe000edf0, value: 0x00030003
Debug: 171 93 target.c:2677 target_write_u32(): address: 0xe000edfc, value: 0x01000000
Debug: 172 99 target.c:2589 target_read_u32(): address: 0xe0002000, value: 0x00000260
Debug: 173 99 target.c:2677 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 174 102 target.c:2677 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 175 105 target.c:2677 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 176 108 target.c:2677 target_write_u32(): address: 0xe0002014, value: 0x00000000
Debug: 177 111 target.c:2677 target_write_u32(): address: 0xe0002018, value: 0x00000000
Debug: 178 114 target.c:2677 target_write_u32(): address: 0xe000201c, value: 0x00000000
Debug: 179 117 target.c:2677 target_write_u32(): address: 0xe0002020, value: 0x00000000
Debug: 180 120 target.c:2677 target_write_u32(): address: 0xe0002024, value: 0x00000000
Debug: 181 123 cortex_m.c:2116 cortex_m_examine(): FPB fpcr 0x260, numcode 6, numlit 2
Debug: 182 126 target.c:2589 target_read_u32(): address: 0xe0001000, value: 0x40000000
Debug: 183 126 cortex_m.c:1830 cortex_m_dwt_setup(): DWT_CTRL: 0x40000000
Debug: 184 129 target.c:2589 target_read_u32(): address: 0xe0001fbc, value: 0x00000000
Debug: 185 129 cortex_m.c:1837 cortex_m_dwt_setup(): DWT_DEVARCH: 0x0
Debug: 186 129 target.c:2677 target_write_u32(): address: 0xe0001028, value: 0x00000000
Debug: 187 132 target.c:2677 target_write_u32(): address: 0xe0001038, value: 0x00000000
Debug: 188 135 target.c:2677 target_write_u32(): address: 0xe0001048, value: 0x00000000
Debug: 189 138 target.c:2677 target_write_u32(): address: 0xe0001058, value: 0x00000000
Debug: 190 141 cortex_m.c:1886 cortex_m_dwt_setup(): DWT dwtcr 0x40000000, comp 4, watch/trigger
Info : 191 141 cortex_m.c:2126 cortex_m_examine(): stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
Debug: 192 141 target.c:1827 target_call_event_callbacks(): target event 21 (examine-end) for core stm32f1x.cpu
Debug: 193 141 target.c:4779 target_handle_event(): target(0): stm32f1x.cpu (cortex_m) event: 21 (examine-end) action:
Debug: 194 144 command.c:146 script_debug(): command - mww 0xE0042004 775
Debug: 196 150 command.c:146 script_debug(): command - flash init
Debug: 198 153 tcl.c:1385 handle_flash_init_command(): Initializing flash devices...
Debug: 199 153 command.c:146 script_debug(): command - nand init
Debug: 201 156 tcl.c:498 handle_nand_init_command(): Initializing NAND devices...
Debug: 202 156 command.c:146 script_debug(): command - pld init
Debug: 204 159 pld.c:206 handle_pld_init_command(): Initializing PLDs...
Info : 205 159 gdb_server.c:3503 gdb_target_start(): starting gdb server for stm32f1x.cpu on 3333
Info : 206 159 server.c:312 add_service(): Listening on port 3333 for gdb connections
^CDebug: 207 7042 server.c:609 sig_handler(): Terminating on Signal 2
Debug: 208 7042 command.c:146 script_debug(): command - shutdown
User : 210 7045 server.c:755 handle_shutdown_command(): shutdown command invoked
Debug: 211 7045 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 212 7049 cmsis_dap.c:848 cmsis_dap_swd_switch_seq(): SWD-to-JTAG
(Notice that ^C, that is when I exited OpenOCD.)
Things still does not work when talking JTAG though:
$ openocd -d3 -f interface/cmsis-dap.cfg -c "transport select jtag" -c "adapter speed 4000" -f target/stm32f1x.cfg
Debug: 25 1 command.c:146 script_debug(): command - adapter driver cmsis-dap
Debug: 27 1 command.c:146 script_debug(): command - transport select jtag
User : 28 1 options.c:63 configuration_output_handler(): jtagUser : 29 1 options.c:63 configuration_output_handler():
Debug: 30 1 command.c:146 script_debug(): command - adapter speed 4000
Debug: 32 1 core.c:1822 jtag_config_khz(): handle jtag khz
Debug: 33 1 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 34 1 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
User : 35 1 options.c:63 configuration_output_handler(): adapter speed: 4000 kHz
User : 36 1 options.c:63 configuration_output_handler():
Debug: 40 2 configuration.c:97 find_file(): found /usr/local/Cellar/open-ocd/0.11.0/bin/../share/openocd/scripts/mem_helper.tcl
Debug: 68 3 command.c:146 script_debug(): command - jtag newtap stm32f1x cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
Debug: 70 3 tcl.c:596 jim_newtap_cmd(): Processing option: -irlen
Debug: 71 3 tcl.c:596 jim_newtap_cmd(): Processing option: -ircapture
Debug: 72 3 tcl.c:596 jim_newtap_cmd(): Processing option: -irmask
Debug: 73 3 tcl.c:596 jim_newtap_cmd(): Processing option: -expected-id
Debug: 74 3 core.c:1488 jtag_tap_init(): Created Tap: stm32f1x.cpu @ abs position 0, irlen 4, capture: 0x1 mask: 0xf
Debug: 75 3 command.c:146 script_debug(): command - dap create stm32f1x.dap -chain-position stm32f1x.cpu
Debug: 76 3 command.c:146 script_debug(): command - transport select
Debug: 77 3 command.c:146 script_debug(): command - jtag newtap stm32f1x bs -irlen 5
Debug: 78 3 tcl.c:572 jim_newtap_cmd(): Creating New Tap, Chip: stm32f1x, Tap: bs, Dotted: stm32f1x.bs, 2 params
Debug: 79 3 tcl.c:596 jim_newtap_cmd(): Processing option: -irlen
Debug: 80 3 core.c:1488 jtag_tap_init(): Created Tap: stm32f1x.bs @ abs position 1, irlen 5, capture: 0x1 mask: 0x3
Debug: 81 3 command.c:146 script_debug(): command - target create stm32f1x.cpu cortex_m -endian little -dap stm32f1x.dap
Debug: 82 3 command.c:376 register_command(): command 'rtt' is already registered in '<global>' context
Debug: 83 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -work-area-phys 0x20000000 -work-area-size 0x1000 -work-area-backup 0
Debug: 84 3 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 85 3 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 86 3 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
Debug: 87 3 command.c:146 script_debug(): command - flash bank stm32f1x.flash stm32f1x 0x08000000 0 0 0 stm32f1x.cpu
Debug: 89 3 tcl.c:1319 handle_flash_bank_command(): 'stm32f1x' driver usage field missing
Debug: 90 3 command.c:146 script_debug(): command - adapter speed 1000
Debug: 92 3 core.c:1822 jtag_config_khz(): handle jtag khz
Debug: 93 3 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 94 3 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 95 3 command.c:146 script_debug(): command - adapter srst delay 100
Debug: 97 3 command.c:146 script_debug(): command - transport select
Debug: 98 3 command.c:146 script_debug(): command - jtag_ntrst_delay 100
Debug: 100 3 command.c:146 script_debug(): command - reset_config srst_nogate
Debug: 102 3 command.c:146 script_debug(): command - transport select
Debug: 103 3 command.c:146 script_debug(): command - cortex_m reset_config sysresetreq
Debug: 105 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event examine-end
Debug: 106 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event trace-config
# assignment
Info : 107 3 server.c:312 add_service(): Listening on port 6666 for tcl connections
Info : 108 3 server.c:312 add_service(): Listening on port 4444 for telnet connections
Debug: 109 3 command.c:146 script_debug(): command - init
Debug: 111 3 command.c:146 script_debug(): command - target init
Debug: 113 3 command.c:146 script_debug(): command - target names
Debug: 114 3 command.c:146 script_debug(): command - stm32f1x.cpu cget -event gdb-flash-erase-start
Debug: 115 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event gdb-flash-erase-start reset init
Debug: 116 3 command.c:146 script_debug(): command - stm32f1x.cpu cget -event gdb-flash-write-end
Debug: 117 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event gdb-flash-write-end reset halt
Debug: 118 3 command.c:146 script_debug(): command - stm32f1x.cpu cget -event gdb-attach
Debug: 119 3 command.c:146 script_debug(): command - stm32f1x.cpu configure -event gdb-attach halt 1000
Debug: 120 3 target.c:1639 handle_target_init_command(): Initializing targets...
Debug: 121 3 semihosting_common.c:99 semihosting_common_init():
Debug: 122 16 cmsis_dap_usb_bulk.c:157 cmsis_dap_usb_open(): found product string of 0x0002:0xda42 'SushiBits One with CMSIS-DAP'
Debug: 123 16 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0002:0xda42
Debug: 124 16 cmsis_dap_usb_bulk.c:237 cmsis_dap_usb_open(): skipping interface 0, has only 1 endpoints
Debug: 125 16 cmsis_dap_usb_bulk.c:285 cmsis_dap_usb_open(): skipping interface 1, class 10 subclass 0 protocol 0
Debug: 126 16 cmsis_dap_usb_bulk.c:224 cmsis_dap_usb_open(): found interface 2 string 'SushiBits One Embedded CMSIS-DAP'
Debug: 127 16 cmsis_dap_usb_bulk.c:244 cmsis_dap_usb_open(): skipping interface 2, endpoint[0] is not bulk out
Debug: 128 16 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1a40:0x0101
Debug: 129 17 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1366:0x0101
Debug: 130 17 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x046d:0xc52b
Debug: 131 17 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x03f0:0x052a
Debug: 132 18 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x04d8:0x9012
Debug: 133 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x03eb:0x2104
Debug: 134 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0002:0xf003
Debug: 135 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0451:0x8140
Debug: 136 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1050:0x0407
Debug: 137 19 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x2109:0x2812
Debug: 138 20 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x046d:0x085c
Debug: 139 20 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x2109:0x2812
Debug: 140 24 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1a86:0x752d
Debug: 141 24 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x0451:0x8142
Debug: 142 24 cmsis_dap_usb_bulk.c:177 cmsis_dap_usb_open(): enumerating interfaces of 0x1a40:0x0101
Info : 143 34 cmsis_dap.c:788 cmsis_dap_get_caps_info(): CMSIS-DAP: SWD Supported
Info : 144 34 cmsis_dap.c:790 cmsis_dap_get_caps_info(): CMSIS-DAP: JTAG Supported
Info : 145 35 cmsis_dap.c:768 cmsis_dap_get_version_info(): CMSIS-DAP: FW Version = 1.0
Info : 146 39 cmsis_dap.c:921 cmsis_dap_init(): CMSIS-DAP: Interface Initialised (JTAG)
Debug: 147 41 cmsis_dap.c:953 cmsis_dap_init(): CMSIS-DAP: Packet Size = 64
Debug: 148 43 cmsis_dap.c:966 cmsis_dap_init(): CMSIS-DAP: Packet Count = 8
Debug: 149 43 cmsis_dap.c:969 cmsis_dap_init(): Allocating FIFO for 3 pending packets
Info : 150 45 cmsis_dap.c:809 cmsis_dap_get_status(): SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 1 nRESET = 1
Info : 151 53 cmsis_dap.c:1023 cmsis_dap_init(): CMSIS-DAP: Interface ready
Debug: 152 53 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 153 53 core.c:1789 adapter_khz_to_speed(): have interface set up
Debug: 154 55 core.c:1785 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 155 55 core.c:1789 adapter_khz_to_speed(): have interface set up
Info : 156 55 core.c:1565 adapter_init(): clock speed 1000 kHz
Debug: 157 55 openocd.c:143 handle_init_command(): Debug Adapter init complete
Debug: 158 55 command.c:146 script_debug(): command - transport init
Debug: 160 55 transport.c:229 handle_transport_init(): handle_transport_init
Debug: 161 57 core.c:830 jtag_add_reset(): SRST line released
Debug: 162 57 core.c:855 jtag_add_reset(): TRST line released
Debug: 163 57 core.c:327 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 164 286 command.c:146 script_debug(): command - jtag arp_init
Debug: 165 286 core.c:1578 jtag_init_inner(): Init JTAG chain
Debug: 166 286 core.c:327 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 167 286 cmsis_dap.c:1076 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET
Debug: 168 288 core.c:1243 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 169 288 core.c:327 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 170 292 cmsis_dap.c:1076 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET
Info : 171 294 core.c:1142 jtag_examine_chain_display(): JTAG tap: stm32f1x.cpu tap/device found: 0x00410041 (mfg: 0x020 (STMicroelectronics), part: 0x0410, ver: 0x0)
Warn : 172 294 core.c:1142 jtag_examine_chain_display(): JTAG tap: stm32f1x.cpu UNEXPECTED: 0x00410041 (mfg: 0x020 (STMicroelectronics), part: 0x0410, ver: 0x0)
Error: 173 294 core.c:1142 jtag_examine_chain_display(): JTAG tap: stm32f1x.cpu expected 1 of 1: 0x3ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x3)
Info : 174 294 core.c:1142 jtag_examine_chain_display(): JTAG tap: stm32f1x.bs tap/device found: 0x00010041 (mfg: 0x020 (STMicroelectronics), part: 0x0010, ver: 0x0)
Debug: 175 294 core.c:1488 jtag_tap_init(): Created Tap: auto0.tap @ abs position 2, irlen 0, capture: 0x1 mask: 0x3
Info : 176 294 core.c:1142 jtag_examine_chain_display(): JTAG tap: auto0.tap tap/device found: 0x00010041 (mfg: 0x020 (STMicroelectronics), part: 0x0010, ver: 0x0)
Debug: 177 294 core.c:1488 jtag_tap_init(): Created Tap: auto1.tap @ abs position 3, irlen 0, capture: 0x1 mask: 0x3
Debug: 178 294 jep106.c:33 jep106_manufacturer(): BUG: Caller passed out-of-range JEP106 ID!
Info : 179 294 core.c:1142 jtag_examine_chain_display(): JTAG tap: auto1.tap tap/device found: 0xff800001 (mfg: 0x000 (<invalid>), part: 0xf800, ver: 0xf)
Warn : 180 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 160 0x80ffffff
Warn : 181 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 256 0xffffff80
Warn : 182 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 320 0xffffff80
Warn : 183 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 384 0xffff80ff
Warn : 184 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 448 0xff80ffff
Warn : 185 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 512 0x80ffffff
Warn : 186 294 core.c:1180 jtag_examine_chain_end(): Unexpected idcode after end of chain: 608 0xffffff80
Error: 187 294 core.c:1319 jtag_examine_chain(): double-check your JTAG setup (interface, speed, ...)
Error: 188 294 core.c:1623 jtag_init_inner(): Trying to use configured scan chain anyway...
Debug: 189 295 core.c:1374 jtag_validate_ircapture(): IR capture validation scan
Debug: 190 296 core.c:1432 jtag_validate_ircapture(): stm32f1x.cpu: IR capture 0x01
Error: 191 296 core.c:1426 jtag_validate_ircapture(): stm32f1x.bs: IR capture error; saw 0x04 not 0x01
Debug: 192 296 core.c:327 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 193 296 cmsis_dap.c:1076 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET
Warn : 194 298 core.c:1646 jtag_init_inner(): Bypassing JTAG setup events due to errors
Debug: 195 298 command.c:146 script_debug(): command - dap init
Debug: 197 298 arm_dap.c:106 dap_init_all(): Initializing all DAPs ...
Debug: 198 298 arm_adi_v5.c:653 dap_dp_init(): stm32f1x.dap
Debug: 199 298 arm_adi_v5.c:685 dap_dp_init(): DAP: wait CDBGPWRUPACK
Debug: 200 298 arm_adi_v5.h:507 dap_dp_poll_register(): DAP: poll 4, mask 0x20000000, value 0x20000000
Debug: 201 298 cmsis_dap.c:1323 cmsis_dap_execute_scan(): discarding trailing empty field
Debug: 202 298 cmsis_dap.c:1323 cmsis_dap_execute_scan(): discarding trailing empty field
Info : 203 304 adi_v5_jtag.c:535 jtagdp_overrun_check(): DAP transaction stalled (WAIT) - slowing down
Error: 204 1306 adi_v5_jtag.c:581 jtagdp_overrun_check(): Timeout during WAIT recovery
Debug: 205 1306 cmsis_dap.c:1323 cmsis_dap_execute_scan(): discarding trailing empty field
Debug: 206 1306 cmsis_dap.c:1323 cmsis_dap_execute_scan(): discarding trailing empty field
Debug: 207 1308 cmsis_dap.c:1323 cmsis_dap_execute_scan(): discarding trailing empty field
Debug: 208 1308 cmsis_dap.c:1323 cmsis_dap_execute_scan(): discarding trailing empty field
Debug: 209 1312 command.c:629 run_command(): Command 'dap init' failed with error code -107
User : 210 1312 command.c:694 command_run_line():
Debug: 211 1312 command.c:629 run_command(): Command 'init' failed with error code -4
User : 212 1312 command.c:694 command_run_line():
Debug: 213 1312 target.c:2172 target_free_all_working_areas_restore(): freeing all working areas
