Cheapest I could find so far was this one:
http://www.ebay.com/itm/ARM-CortexM3-STM32F103C8T6-STM32-Core-System-Development-JTAG-AMS1117-33-Board-/301283707327
Hmmm, yes, but scroll down the page to the full product description. It's the same board, and you can read the STM32F103... on the chip, but have a read of the description at the very end:
1 PCS BC04-B Bluetooth to UART Module Industrial Master-Slave Wireless Bluetooth
Article-Nr.:5200137
Product Details:
Condition: New
Description:
1. Adopt the mainstream CSR bluetooth chip, the bluetooth V2.0 protocol standard
2. Serial port module working voltage 3.3 V, Transmission distance is about 15 meters
3. Default baud rates is 9600,it can be set by user
4. Working status indication, connection and disconnected status signal output, is advantageous for the MCU to track the state of module
5. Core module size: 26.7 x 13 x 2.2 mm
6. Working current:matching: 2~30mA .matched but not communication: 5~6mA communicating: 10mA
7. Sleep current: don't sleep, but support low power mode
8. Used for GPS navigation systems, water and electricity gas meter reading system, industrial control system
9. Can add bluetooth adapter with bluetooth laptops, computers, PDA and other equipment for seamless connection
Specification:
1. Bluetooth protocol: Bluetooth Specification v2.1+EDR
2. USB protocol: USB v1.1/2.0
3. Frequency: 2.4GHz ISM band
4. Modulation: GFSK(Gaussian Frequency Shift keying)
5. Transmission power: 4dBm, Class 2
6. Sensitivity: -84dBm at 0.1% BER
7. Rate:Asynchronous: 2.1Mbps(Max)/160 kbps,Synchronous:1Mbps/ 1Mbps
8. Security features: Authentication and encryption
9. Support profiles: SPP(master & slave)
10. Power supply: +3.3VDC 50mA
11. Working temperature: -20~+55 Centigrade
12. Size: 26.7mm x 13mm x 2.2 mm
NOTE :BC04-B is the master-slave integrated bluetooth serial port module,Master-slave can be changed by command
Color and more details are shown as pictures
PLS NOTE that due to lighting effects, monitor's brightness/ contrass settings ect, there could be some slight differences in the color tone of the pictures and the actual item!
Package Included:
1 x BC04-B Bluetooth to UART Module
Still, for $8.21 it's hard to quibble, and what appears to be the same board is also advertised on that same page for $7.96, and then $6.59.
