Author Topic: What pins are pwm capable with stm32f103rct6?  (Read 2155 times)
Offline tesliniusTopic starter
« on: May 08, 2022, 09:31:41 pm »
I want to find out what pins are pwm capable for stm32f103rct6 microcontroller, all pins with timers?
Also how can i remap functions, because for example with pin PA15 doesn't have any timers by default, but if i remap it it should have it?
Offline DavidAlfa
Re: What pins are pwm capable with stm32f103rct6?
« Reply #1 on: May 08, 2022, 10:02:21 pm »
Check AFIO in the RM. And properly read the GPIO section.
Offline wek
  • Country: sk
« Reply #2 on: May 08, 2022, 10:53:47 pm »
For mapping of particular pins to peripherals (here: timers), see pin definitions table in datasheet (DS).
As DavidAlfa said above, remap is given by the AFIO registers, described in the RM.
JW
Offline tepalia02
  • Country: bd
« Reply #3 on: May 22, 2022, 11:24:27 am »
If you're using the Blue pill, take a look at the 3rd figure. https://www.electronicshub.org/getting-started-with-stm32f103c8t6-blue-pill/
