Author Topic: Interfacing Nokia 1200 with microcontrollers  (Read 1822 times)
Offline pulverizers
« on: July 31, 2013, 02:00:52 pm »
After a frantic search for info on using the nokia 1200 via f-bus, i've decided to post on the forum for help.
AFAIK, nokia 1200 uses f-bus protocol ver 3 which is not well documented on the web. What should I do to interface it with MCU to send SMS,calls etc?
Offline ivan747
Re: Interfacing Nokia 1200 with microcontrollers
« Reply #1 on: August 07, 2013, 02:22:17 am »
Does it really have to be that phone? You could have it much more easy if you had a phone that could be fed standard AT commands via RS-232.
Offline Psi
« Reply #2 on: August 07, 2013, 02:27:38 am »
Some cheap gps car trackers with cell chips can be hacked easily to accept AT commands.
Don't ask my for specific models though.
