I just received my epulse ESP32 board order. It was delayed due to COVID19, but made it to NZ quicker than expected.
I quickly hooked up a PSU and a few meters to measure the power usage.
* 27.4 mA with the CPU running (no Wifi running)
* 23.5uA when the CPU is in deep sleep (with a timer running for wakeup).
In the pictures the uA is on the meter in the center, the mA on the right.
That is pretty good for a US$16.90 ESP32 board. The 3V3 LDO they are using is the TS9013SCW - might have to get some!
https://thingpulse.com/product/epulse-low-power-esp32-development-board/PS. The uA meter has a piss-poor shunt over it until the board goes into deep sleep, hence the 300nA reading when measuring the mA.
EDIT: Correct SI unit prefix error... Opps!
