Author Topic: Interfacing 433mhz Remote Control Key FOB  (Read 3330 times)
Offline maurosmartinsTopic starter
  • Country: pt
    • Electronics and Embedded systems
« on: September 17, 2017, 06:14:44 pm »
Hello all!
For a recent idea that I had I need a remote with one or two keys, the typical electric garage remote would be perfect because of its form factor and price on ebay for example.
eBay auction: #http://www.ebay.com/itm/Universal-Electric-Gate-Garage-Door-Remote-Control-Key-FOB-Cloning-Cloner-433mhz-/152435429297?epid=600821686&hash=item237ddc0fb1:g:uY8AAOSw32lYoWiG
My question is, how to interface this (receptor) with a microcontroller and what to expect.
Does anybody have done this before? Any help would be good!
Thanks in advanced best regards Mauro.
Offline PA0PBZ
Re: Interfacing 433mhz Remote Control Key FOB
« Reply #1 on: September 17, 2017, 06:43:46 pm »
I'm not sure what you want to do with it and your link doesn't work for me but I guess this is a remote control made to clone another remote control.
If you want something to wireless control a microcontroller it can be done a lot cheaper, see for instance:
http://www.ebay.com/itm/433Mhz-RF-Transmitter-And-Receiver-Modules-for-Arduino-ARM-MCU-Remote-Control-/132259659198
  • Country: pt
« Reply #2 on: September 17, 2017, 07:10:09 pm »
Hello PA0PBZ,
I would like to use one of these to trigger an action, I would like to use it because Of its form factor. I can carry this easilly in my pocket.
What I need to know is how to receiver the key press on the microcontroller.
Best regards  Mauro.
Offline MattHollands
    • Matt's Projects
« Reply #3 on: September 18, 2017, 04:39:29 pm »
Hello PA0PBZ,
Best regards  Mauro.
Most keys operate on 433MHz. I've had a lot of success using the HopeRF RFM69 module. You can find Arduino libraries online and I ported it to the MBED platform on my github.
Read about my stuff at: projects.matthollands.com
Offline paulcav
« Reply #4 on: September 19, 2017, 08:26:50 am »
Best regards  Mauro.
Hi mauro,
Most of these FOB transmitters come with a reciever
with this receiver it will output on one of the pins to correspond to the keypress. It is based on IC2262/2272 chips. IC Datasheet here.
Have a look here for one that i think will meet your requirements.
This is a datasheet that you can use here
« Last Edit: September 19, 2017, 08:49:42 am by paulcav »
  • Country: pt
« Reply #5 on: September 19, 2017, 10:57:18 am »
Hello paulcav and MattHollands, thank you very much for your replies.
paulcav, thank you for such complete answer, this helps me a lot, it is very easy to integrate.
MattHollands, you are using the RFM69 for "listening" for those key fobs, or you are suggesting using the RFM69 for creating a 433MHz link? if is for creating the link it is not good for me, I would like to use the already existent key fobs because they are cheap and can easily transported in the pocket.
Best regards, Mauro.
    • Matt's Projects
« Reply #6 on: September 19, 2017, 11:03:08 am »
I'm suggesting "listening" for those keyfobs. By putting the RFM69 into OOK mode and setting it to a certain frequency, it will fully decode all data sent on that frequency and output it on a pin. You can look for the correct codes for the buttons. In fact I think you can make the module detect codes itself.
Offline paulcav
« Reply #7 on: September 19, 2017, 11:53:16 am »
If you want to use device with relays you can have an idea with this one
here
« Last Edit: September 19, 2017, 12:01:39 pm by paulcav »
Offline AlessandroAU
« Reply #8 on: September 22, 2017, 02:20:00 pm »
Check out my GitHub project:
https://github.com/AlessandroAU/ESP8266-433Mhz-and-IR-Bridge-MQTT
You can receive and duplicate those 433mhz OOK/ASK packets with very little hardware. (ESP8266 + 433Mhz modules)
