Author Topic: NUVOTON NUC980 (ARM926EJ-S) - Non OS DMA transfer to GPIO  (Read 3117 times)
Online up8051Topic starter
« on: December 10, 2023, 01:21:07 pm »
Hello,
Does anyone use Nuvoton's NUC980 processor?
I'm trying to start DMA transmission (Memory -> GPIO) triggered by Timer0 but I can't do it.
Non OS  firmware.
Regards,
JarekC
Re: NUVOTON NUC980 (ARM926EJ-S) - Non OS DMA transfer to GPIO
« Reply #1 on: December 14, 2023, 01:03:14 pm »
I managed to get contact information for Nuvoton FAE, but no response yet.
Nuvoton has a technical forum but it is currently closed, you cannot register.
Nuvoton seemed to be quite a well-known brand and I was hoping for better support.
But as you can see, it's better to stick to popular brands (NXP, STM, Microchip....).
The NUC980 seemed like a good choice because of its small footprint (TQFP64) and plenty of RAM 32/64MB.
If my problem is not solved quickly, I will probably change the chip to STM32H7xx and external Dual QSPI PSRAM.
BR JarekC
« Reply #2 on: December 25, 2023, 05:10:03 pm »
Unfortunately, after two weeks of contacting Nuvoton support, I did not receive any advice on how to solve the problem  |O.
There are already 6 people from Nuvoton on the mailing list, but no response regarding technical issues.
If the problem cannot be solved by the end of the year, I will change the processor to STM32H7xx (I have already ordered starter kits).
The conclusion is that before you choose a processor for a project, check the support.
BR JarekC
Online jnk0le
« Reply #3 on: December 26, 2023, 12:14:36 am »
In this case, make sure to source parts with "OCTO SPI" peripheral as the "QSPI" doesn't work with PSRAMs as expected.
« Reply #4 on: December 26, 2023, 08:38:18 am »
Can you provide more details?
« Reply #5 on: December 26, 2023, 11:46:37 am »
I am completely disappointed.
According to FAE, NUC980 cannot transmit data via DMA from RAM to GPIO, there is no information about this limitation in the Technical Reference Manual.
Online jnk0le
« Reply #6 on: December 26, 2023, 09:18:45 pm »
"QSPI" peripheral doesn't support writes in memory mapped mode as well as refreshing.
