Electronics => Microcontrollers => Topic started by: hamster_nz on November 15, 2017, 09:16:08 am
After a tweet from John at Expressif, I finally got to prove to myself that ESP32 can sleep at <7 uA - on a WeMos LoLin32 board I was getting 890uA.
After downloading my test code to the flash, I lifted the (not that great) 3V3 regulator and powered it from a bench supply.
https://www.youtube.com/watch?v=CtuWPBw065Y (https://www.youtube.com/watch?v=CtuWPBw065Y)
about 28mA when awake, and < 0.1mA when asleep.
I had rigged up a toggle switch so I could switch in a uA meter while it was asleep, and the results are in - 6.22uA while asleep, and waking up like clockwork.
Code as used (sorry, it still has some debugging of the power registers in there)
... header files ...
#define MHZ (1000000)
const static char *TAG = "deepsleep";
void app_main(void)
ESP_ERROR_CHECK( nvs_flash_init() );
while(1) {
ESP_LOGI(TAG, "Awake\n");
WRITE_PERI_REG(RTC_CNTL_PWC_REG, 0x00120240);
ESP_LOGI(TAG, "RTC_CNTL_OPTIONS0_REG 0x%08x", READ_PERI_REG(RTC_CNTL_OPTIONS0_REG));
ESP_LOGI(TAG, "RTC_CNTL_ANA_CONF_REG 0x%08x", READ_PERI_REG(RTC_CNTL_ANA_CONF_REG));
ESP_LOGI(TAG, "RTC_CNTL_PWC_REG 0x%08x", READ_PERI_REG(RTC_CNTL_PWC_REG));
ESP_LOGI(TAG, "RTC_CNTL_DIG_PWC_REG 0x%08x", READ_PERI_REG(RTC_CNTL_DIG_PWC_REG));
sleep(2);
ESP_LOGI(TAG, "Entering deep sleep\n");
sleep(1);
esp_deep_sleep(15*MHZ);
ESP_LOGI(TAG, "Sleep failed\n");
sleep(1);
