Hi All,
I am writing code for ESP32 module in Arduino IDE for interfacing between ESP32 module and Mobile application through Bluetooth BLE mode.
I had established connection between ESP32 and Mobile application. And also I could send data between mobile to ESP32 and ESP32 to Mobile.
My task is capturing ADC data in ESP32 module and send to Mobile application. But ADC capturing starts when Mobile send command to ESP32, i.e command "START", then send 1000 times ADC data to Mobile Application. After that wait for next "START" command, then starts the same process again.
The problem is, ESP32 receives command from Mobile, but ESP32 didn't starts the ADC capturing process. And also I tried , like once Mobile connects the ESP32 through Bluetooth BLE mode, ESP 32 starts capturing ADC data and send to Mobile Application properly. I also received data in Mobile Application. But this ADC capturing didn't happened in send command from Mobile to ESP32. The following is the code what I wrote.#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
//////////Variable Declaration of BLE/////////////////////////////
BLECharacteristic *pCharacteristic;
bool deviceConnected = false;
float txValue = 0;
std::string rxValue;
volatile bool BLE_CMD = true;
#define SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
/////Variable Declaration of ADC calculation////////////////////
const int IO34_ADC = 34;
const int IO35_ADC = 35;
float IO34_ADC_VALUE = 0;
float IO34_voltage_value_min = 0;
float IO34_voltage_value_max = 0;
int IO34_ADC_VALUE_SUM = 0;
float IO34_ADC_VALUE_AVG = 0;
float IO34_VOLtAGE = 0;
float IO35_ADC_VALUE = 0;
float IO35_voltage_value_min = 0;
float IO35_voltage_value_max = 0;
int IO35_ADC_VALUE_SUM = 0;
float IO35_ADC_VALUE_AVG = 0;
float IO35_VOLtAGE = 0;
int ADC_Buffer_34[500];
int ADC_Buffer_35[500];
int ADC_34_min[50], ADC_34_max[55], IO_34_min, IO_34_max;
int ADC_35_min[50], ADC_35_max[55], IO_35_min, IO_35_max;
#define Vref 3.3
#define ADCResolution 4096 //12-bit SAR ADC
int f_l_i, f_l_j, f_l_k; // FOR for loop
float AVERAGE(int arr[], int n)
int i;
int sum=0;
float avg;
for(i=0; i<n; i++)
sum = sum + arr[i] ;
avg = sum / n;
return avg;
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks
void onWrite(BLECharacteristic *pCharacteristic)
rxValue = pCharacteristic->getValue();
if (rxValue.length() > 0) {
Serial.println("*********");
Serial.print("Received Value: ");
for (int i = 0; i < rxValue.length(); i++) {
Serial.print(rxValue[i]);
Serial.println();
void setup() {
Serial.begin(115200);
// pinMode(LED, OUTPUT);
// Create the BLE Device
BLEDevice::init("ESP32 UART Test"); // Give it a name
// Create the BLE Server
BLEServer *pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_TX,
BLECharacteristic::PROPERTY_NOTIFY
pCharacteristic->addDescriptor(new BLE2902());
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_RX,
BLECharacteristic::PROPERTY_WRITE
pCharacteristic->setCallbacks(new MyCallbacks());
// Start the service
pService->start();
// Start advertising
pServer->getAdvertising()->start();
Serial.println("Waiting a client connection to notify...");
void loop() {
if (deviceConnected) {
BLE_CMD = true ;
if (rxValue =="START")
for(unsigned long i_1min = 0; i_1min < 1000; i_1min++)
if(BLE_CMD == true)
for(f_l_i = 0;f_l_i < 145; f_l_i++)
ADC_Buffer_34[f_l_i] = analogRead(IO34_ADC);
ADC_Buffer_35[f_l_i] = analogRead(IO35_ADC);
IO34_ADC_VALUE = AVERAGE(ADC_Buffer_34, 145);
IO35_ADC_VALUE = AVERAGE(ADC_Buffer_35, 145);
///////////////////////////////////////ADC Calculation//////////////////////////////////////////////////////////////////////////////////////////
IO34_VOLtAGE = (float) (IO34_ADC_VALUE * Vref ) / (ADCResolution);
IO35_VOLtAGE = (float) (IO35_ADC_VALUE * Vref ) / (ADCResolution);
char tx1String[8];
char tx2String[8];
dtostrf(IO34_VOLtAGE, 1, 2, tx1String);
dtostrf(IO35_VOLtAGE, 1, 2, tx2String);
//////////////////UART Window///////////////////////
Serial.print("9999TH1_");Serial.print(IO34_VOLtAGE);Serial.print("XXTH2_");Serial.print(IO35_VOLtAGE);Serial.print("XXXX\n");
////////////////BLE Window///////////////////////
pCharacteristic->setValue("9999TH1_"); pCharacteristic->notify();
pCharacteristic->setValue(tx1String); pCharacteristic->notify();
pCharacteristic->setValue("XXTH2_"); pCharacteristic->notify();
pCharacteristic->setValue(tx2String); pCharacteristic->notify();
pCharacteristic->setValue("XXXX\n"); pCharacteristic->notify();
///////////////////End Packet : UART////////////////
Serial.print("9999EEEEEEEEXXEEEEEEEEXXXX\n");
///////////////////End Packet : BLE////////////////
pCharacteristic->setValue("9999EEEEEEEEXXEEEEEEEEXXXX\n"); pCharacteristic->notify();
rxValue = "TEMP_STOP";
delay(50);
Please let me know, where I did mistake and suggest how I can finish the task expected way.
Advances in thank you All.
