Author Topic: Help with this MAX7219 MATRIX DISPLAY!  (Read 932 times)
Offline kgavionicsTopic starter
« on: December 04, 2024, 03:24:10 pm »
Hello
I got a few of these Chinese Matrix display based on the Max 7219 chips, but none of them is working. The connection seems to be correct. All CLK, DIN AND CS pins are tied together and CHIP 3 DOUT going to chip 2 DIN, chip 2 DOUT is going to chip 1 DIN, CHIP 1 DOUT is going to chip 0 DIN.
As a matter of fact, I tried a lot of library and the result is always the same (see picture 2). In this example, I'm writing "1 9 7 3" string on the display. Does someone have an idea what's going on? TIA
« Last Edit: December 04, 2024, 03:57:06 pm by kgavionics »
Re: Help with this MAX7219 MATRIX DISPLAY!
« Reply #1 on: December 04, 2024, 05:46:19 pm »
I fixed the problem by changing the type of display from PAROLA_HW to FC16_HW
