Author Topic: PDS Bitcloud Zigbee Stack  (Read 1110 times)
Offline Swati ChikmathTopic starter
  • Country: in
« on: June 24, 2021, 02:50:31 pm »
Hello Everyone,
Is their any restriction to use PDS to store data in non volatile memory when the node in zigbee network is programmed as coordinator?
As I have programmed with the file descriptor MEM_ID, Storing and restoring data using PDS_Store and PDS_Restore function. I dont find value being store in PDS and restored from PDS.
I have carried out this process in Zigbee bitcloud on ATSAMR21G18A microcontroller board.
Look for your suggestions
Thank you
