Author Topic: Etymology of the word register  (Read 1094 times)
Offline slugrustle
« on: February 02, 2023, 02:48:03 am »
Does anyone know the etymology for the word "register" as used in microcontrollers?  Where does it come from, historically?
Offline TimFox
Re: Etymology of the word register
« Reply #1 on: February 02, 2023, 02:56:22 am »
A typical dictionary definition of the term "register" before its use in computers:
"a written record containing regular entries of items or details"
as in an old-fashioned hotel register where guests write their names and contact information in the book.
Offline cantata.tech
« Reply #2 on: February 02, 2023, 03:00:13 am »
Sure.
Before I say anything, I need to point out that the origins of the word are contested on the internet and it's now claimed to be a 'Christian' word coming from Latin (Etruscan). I find it to be older than that.
"Register" is based on the old Phoenician particle 'gimmel'.
The root particle is gér. That means "Hold" something. Also coins, money, War, arm or weapons.
Also carried through French/Gallic as the word 'ongérer' or Guerre.
Therefore the word "re+gi+ster" literally means 'temporary holding thing'.
« Last Edit: February 02, 2023, 04:38:28 am by cantata.tech »
The following users thanked this post: jpanhalt
Offline brucehoult
« Reply #3 on: February 02, 2023, 04:18:23 am »
If you're content to go back only a few hundred years, Babbage used the term in his difference engine around 1820, as did people making simple adding machines in the early 1600s.
No doubt they got it from accountants.
Online SiliconWizard
« Reply #4 on: February 02, 2023, 08:14:31 pm »
Yes a register is simply some support where you'd store some information. The term has been used for a lot of purposes in the past, it goes way beyond accountants.
A common form of the same word is "registry", which is more about the medium where information is recorded.
It comes from the latin "registrum".
https://en.wiktionary.org/wiki/registrum
Offline NorthGuy
« Reply #5 on: February 02, 2023, 10:31:02 pm »
I always thought that it comes from flip-flops. On every clock, flip-flops register their inputs (i.e. recognize, record) and hold them. Hence, people started to call flip-flop registers. Then when flip-flops where used in computers the word register moved on to the computer's world.
I don't think this has anything to do with collections of records. That would be registry.
Offline thm_w
  • Non-expert
« Reply #6 on: February 02, 2023, 10:39:19 pm »
"A register is an official list or record of people or things."
https://www.collinsdictionary.com/dictionary/english/register-records
what?
Offline brucehoult
« Reply #7 on: February 02, 2023, 11:30:17 pm »
As already mentioned, early 1600s mechanical adding machines with numbers being calculated with stored in the rotational position of wheels/gears, with one decimal digit per wheel, called each collection of wheels holding one number a "register".
That's a little before flip-flops.
Offline Doctorandus_P
« Reply #8 on: February 03, 2023, 12:48:34 am »
Another thing:
In the old days, "computer" was a job title. At some times those jobs got pushed out of the market by some kind of machine.
Offline amyk
« Reply #9 on: February 03, 2023, 03:04:23 am »
...and only slightly more recently than that, the cash register.
The word "accumulator" also has similar roots.
Offline TimFox
« Reply #10 on: February 03, 2023, 03:45:31 am »
Another thing:
Richard Feynman's job at the Manhattan Project was running the "computers", most of whom were non-commissioned officers, typically corporals.
They were organized into gangs of calculation, using mechanical desk calculators, to compute what would now be done in "computers".
Offline brucehoult
« Reply #11 on: February 03, 2023, 05:26:08 am »
I actually checked that. Surprisingly, cash registers seem to start from around 1890, more thnn 250 years after those early 1600s adding machines (and half a century after Babbage), NOT before them.
« Reply #12 on: February 03, 2023, 06:01:30 am »
Not that I can see, it uses a different root particle.
"Accumulator" uses the root particle "sum" as c and s are interchangeable so that Accumulator can also be pronounced as "A+sum+ulator".
"Sum" makes contextual sense.
Sum means a) "A central idea or point"
                  b) The utmost degree (or utmost register)
                  c) An arithmetic computation
These root particle meanings are older than the Roman Empire or the Latin language, although it will be claimed by 'some' [a countable quantity] that these words are all Latin derived.
