The optical input for both detectors is an optic fibre of different lengths.
a replacement for the Hameg's 8122/8123 interval measurement.
It's clear now, thank you.
That should work, but does anyone know of a better or more elegant solution?
Wouldn't be more convenient to use a dual channel oscilloscope, instead of building a dedicated counter?
A low entry 4 channels DSO, e.g. Rigol DS1054Z, would be able to visualise the pulses, one on each channel. Fastest sweep is 5ns/division, and a division is about 1cm on the screen. Max sampling rate is 1Gsa/s, so 1ns is visible, and the signal can be frozen on the screen for more detailed inspection/explanations. In fact, for 2 channels is half of 1Gsa/s, but 1ns is about 30cm, so 100m of optical path is no problem to see, even with the slower 2ns resolution. (3 or 4 channels simultaneous is done at 1/4 GSa each).
Then, with the oscilloscope, the same experiment can be repeated with electric impulses in an electric cable, instead of light. By doing time domain reflectrometry (TDR) with an electric cable, no photodectors would be needed, and while sending the pulses to the cable, the other end can be snipped away shorter and shorter, live, so the students will see the reflected pulses coming back faster and faster while they keep snipping away from the other end of the cable. Eventually a 3rd oscilloscope channel can be used , etc.
Any school should have an oscilloscope for the physics classes. Nothing can beat "seeing" the results as a waveform.
If the school can afford an oscilloscope about $3-400 before taxes, see the exact price for EU at
www.batronix.com. Maybe pay a 100 extra to get a 4 channel oscilloscope that also includes a signal generator, like
DS1074Z-S. Batronix offers some other models from Siglent, too, or more expensive brands like Rohde & Schwarz.
