Author Topic: externally triggered time counter in verilog  (Read 4585 times)
Offline fabioacostaTopic starter
« on: November 03, 2014, 04:15:14 am »
Hi I'm new to the fpga world, just got a Xilinx Spartan 3E and started playing around with it in verilog with ISE design tools.
My frustration came when I try to use 2 external triggers to activate counters. My goal is to make a program that when given 3 posedges of a push button in a range of 5 seconds turns on a led. If the 5 seconds go and there haven't been 3 events from the push, resets and restart the process.
I tried to code this and the concept was something like this
Always@(posedge push)
**if first push then flag=1**
Always @(posedge clock)
** if flag==1 then start counter
       **check function for pushes and time reset
This had the issue that I had to change registers on both blocks so I've been told to put both processes in one block. The problem with it is that I don't see a way to make the push posedge work since the clock is always faster.
Is there a way for me to activate a clock counter after another posedge event and make it synthesizable. I know for a fact this is a possible implementation  using a counter that controls another one via reset or enable and I would just make it through schematic if it wasn't for the absurdly large counter that is needed with a 50Mhz clock.
Please help me with this and I'll be eternally grateful.
Offline jahonen
Re: externally triggered time counter in verilog
« Reply #1 on: November 03, 2014, 11:04:40 am »
You'll need to synchronize the push signal to your clock so that they have guaranteed (or almost, excluding metastability probability :) ) timing relationship. Then generate "edge flag" for the push signal. I suck at verilog so in VHDL something like
signal push : std_logic;
signal push_rise : std_logic;
push_sync: process(clk, reset)
  variable sreg : std_logic_vector(2 downto 0); -- adjust length for desired metastability protection
begin
  if reset = '1' then
    sreg := (others => '0');
    push <= '0';
  elsif rising_edge(clk) then
    push <= sreg(sreg'left);
    sreg := sreg(sreg'left-1 downto 0) & push_in; -- push_in is the unsynchronized signal
  end if;
end process;
push_edgedet: process(clk, reset)
  variable prev : std_logic;
  if reset = '1' then
    prev := '0';
    push_rise <= '0';
    push_rise <= '0';
    if prev /= push and push = '1' then
      push_rise <= '1';
    end if;
    prev := push;
  end if;
end process;
Now the push_rise is the signal which goes to '1' for one clock period whenever a rising edge is detected, so you can read it safely in your synchronized counter. I guess that it comes from some push-button so it is left an exercise to the reader to implement a debounce for that signal.
Regards,
Janne
« Last Edit: November 03, 2014, 11:09:31 am by jahonen »
Online langwadt
« Reply #2 on: November 06, 2014, 12:09:41 am »
unless you have very specific needs or want to make life difficult run everything synchronous on a
single clock
i.e. sample the button input on the clock edges, detect the change from low to high use that
to control state machine that counts down from 5 seconds, once it sees the first "pushed"
Offline hamster_nz
« Reply #3 on: November 06, 2014, 08:46:14 pm »
Depending on exactly what you want there is many different ways to skin the cat. Here's how I would do it (in a gibberish pseudo code)
on the posedge of the external clock
   // Detect when you need to respond to the button press
   if btn_debounced_last = '0' and btn_debounced = '1' and led = '0' then
       if counter = 0 then
           // Start the counter for five seconds
           counter = clock_freq * 5 - 2;
       elsif press2 = 0 then
           // Flag that we have seen a second press
           press2 = '1';
       else
           // We've seen the third press!
           // Turn on the LED and set up a five second timeout
           led = '1';
           counter = clock_freq * 5 - 1;
       end if;
   else
        if counter != 0 then
          counter = counter -1;
        else
           // Reset state
           press2 = '0';
           led = '0';
        end if;
   end if;
   btn_debounced_last = btn_debounced;
It's not perfect, and doesn't show how to debounce the button input, but logic looks OK to me at first glance.
