Author Topic: Faulty FPGA?  (Read 1813 times)
Offline BoscoeTopic starter
Faulty FPGA?
« on: April 23, 2017, 02:25:13 pm »
I'm having some strange issues with an FPGA on a custom board. I had copied and pasted he design and layout from a previous project that didn't have any issue so I'm confident the design is okay.
The issues I'm having are:
- A few GPIOs do not go to the VCCIO voltage (3.3V) instead they only reach around 1.4V and are very flaky with the pressure I apply with the probe making a difference.
- I'm try to use a PLL to create 80MHz from 100MHz which isn't working at all.
I assembled the PCB myself, the FPGA is an EP4CE6E22N, I've assembled a lot of PCBs in my time so confident it's okay. Could these issues be caused by ESD or a faulty IC?
Thanks
Offline radar_macgyver
Re: Faulty FPGA?
« Reply #1 on: April 23, 2017, 02:46:58 pm »
Sounds like a dry joint to me, possibly on a power pin.
Re: Faulty FPGA?
« Reply #2 on: April 23, 2017, 03:29:37 pm »
I forgot to mention if I assign the pin a value such as 'ft_nrst = 1' in the signal list in the top module without any other driver I get the issue however only on a couple of pins. If I do not assign it in the signal list and do 'assign ft_nrst = 1' in the code section it does work. Anyone know why this might be the case?
Offline Daixiwen
  • Country: no
Re: Faulty FPGA?
« Reply #3 on: April 24, 2017, 07:28:39 am »
Is the exposed pad properly connected to ground? A common problem on the E144 package is a bad connection on the exposed pad, giving all kind of weird problems.
Offline marshallh
    • retroactive
Re: Faulty FPGA?
« Reply #4 on: April 25, 2017, 02:26:02 am »
This, all sorts of weird phenomena occur if the center pad is not WELL soldered. If you want to hand solder it you bascally have to make a board cutout and manually solder it from underneath. Never had a problem reflowing them.
Verilog tips
BGA soldering intro
