I Don't want to buy a logic analyzer, or a new oscilloscope, but sometimes (like now), i'm in a situation where I need to monitor multiple TTL signals.
So I'm trying to build one DIY-style. I don't aim to achieve high frequencies. My goal is to achieve te highest possible bandwith with the hardware that i already have
(often i can drive the circuit at a much lower clock frequency to test it).
I grabbed my Easypic v7 devboard from Mikroe with a PIC18f45k22. This thing has a 4x PLL and a 16MHz internal Oscillator. The PIC runs on 64Mhz. This means that 16 million instructions can be executed in a second. People are now screaming at me that i should use a FPGA or something like that, but that's maybe something for a future project. First try with the things that i have now. (a pic devboard, a pc....-
The best display i have is... my pc, I want to learn how to write a program that displays the waveforms.
I am a bit familiar with Java for simple programs, but maybe i'll try to do it wit c#.NET. I still need to do some research how to create waveforms in such a program. If anyone can help me with this?
So far so good, i created a little program in JAL (just another language), that reads the µc PORTD and sends it over the usb-uart to my laptop.
This program works just fine, in a terminal window (putty), i see the numbers representing the signals at the corresponding pins on the pic.
one thing that makes me worry is that i can't achieve high baudrates? Is a PLL/INTOSC such an unstable clock that it will generate rubbish at 115200 baud?
I'm now stuck at 2400 Baud. (maybe a bit higher should work, but at 9600 things start to go wrong).
Can i enhance the baudrate in a way that it still is reliable and doesn't generate rubbish when having a look at the data in putty terminal?
