Yeah, looks like there is no calibration data in those devices. They may be engineering samples or something.
For the actual temperature reading, you will get better results if you use lookup table anyway. Just collect what ADC readings correspond to what temperatures and use that table to lookup the temperature based on the ADC reading. This table will be non-linear, so you will get better results than any linear approximation.
There may be some variability between the devices, so you will need to check that as well.
