Electronics => Microcontrollers => Topic started by: patpat on August 14, 2017, 03:47:03 pm
Fluke 19X/B/C/II Firmware to Binary converter
FlukeFW2Bin.exe takes the firmware file (Tetra.ldf, or data.bin) from within Fluke's FlashTool
(F190_II_V11.44.exe, FlashTool_19xC_2xC_V804.exe, FlashTool_F190C_V615.exe, etc.)
and converts it into 2 binary files for analysis purposes.
The firmware on these Fluke Scopes uses the Nucleus PLUS - Version CL7111A RTOS what means
the uP is some form of ARM little-endian CL7111A probably similar to CIRRUS LOGIC CL-PS7111
The produced files binary must be loaded at 0x40000000 and 0x44000000
Entry point 0x40000080
Best,
Pat
Since all of these use the same hardware - can a B version be converted to a C version?
Well the displays are essentially different but I do not know about the bandwidth differences.
At the moment I just looked a bit at the code related to the undocumented console commands.
EO ?
EX ? Check Memory
FM ?
GD GET DOWN
GL GO TO LOCAL
GR GO TO REMOTE
HO HOLD
ID IDENTIFICATION
IM ?
IS INSTRUMENT STATUS
KY ?
PC PROGRAM COMMUNICATION
PS PROGRAM SETUP
PW ?
QC ?
QI ?
QM QUERY MEASUREMENT
QP QUERY PRINT
QS QUERY SETUP
QW QUERY WAVEFORM
RB ?
RC ?
RD READ DATE
RI RESET INSTRUMENT
RN ?
RP REPLAY
RS RECALL SETUP
RT READ TIME
RW ?
SO SWITCH ON
SS SAVE SETUP
ST STATUS QUERY
TA TRIGGER ACQUISITION
VE ?
WB ?
WC ?
WD WRITE DATE
WT WRITE TIME
WW ?
EXTENSION COMMAND TABLE (RAM 0x444000000)
CF ?
EO ?
FC ?
PF ?
QF ?
TI ?
FP ?
In the service manual Fluke states that the specific model is set when the main board is replaced. It can only be done at a Fluke service center.
My guess is that the run a console setup or modify an identification string.
The screen is just color. But it may be that a BW screen will be unreadable if the output is color.
Thanks for figuring out the console commands.
Does anyone know how to run the FlukeFW2Bin.exe utility, things like OS environment, commands, etc.? It does not come with any guide or readme.txt in the zip package.
Thanks,
Ken
