Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
Best forum for IAR EWARM wanted
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Best forum for IAR EWARM wanted (Read 3486 times)
euzer
Contributor
on:
May 13, 2014, 12:12:46 pm »
Can anyone recommend a non-processor specific forum covering IAR EWARM, or failing that the most popular processor-specific forum for it?
I'd like to know if there's a way to compare two different build configurations without manually inspecting the multitude of settings in the project/file options dialogue boxes.
Logged
jmag999
Contributor
Country:
Re: Best forum for IAR EWARM wanted
Reply #1 on:
May 13, 2014, 12:47:14 pm »
Try Winmerge on the project file.
http://winmerge.org/
Logged
dannyf
Super Contributor
Country:
Reply #2 on:
May 13, 2014, 01:27:00 pm »
IAR may have a forum for that.
As far as I know, no automated tools exist for that.
Logged
fake-name
Regular Contributor
Reply #3 on:
May 14, 2014, 05:06:07 am »
Does it use ASCII configuration files (if it doesn't, it should).
Those should be pretty easy to diff using one of the many tools for that out there.
Logged
euzer
Contributor
Reply #4 on:
May 14, 2014, 09:46:46 am »
It uses xml. All the settings for all build configurations and any overridden files are contained within one file so they have to be split out to separate files to diff them and then the xml tags for any different settings need interpreting. All quite a laborious process and not a great improvement on manual comparison of dialogue box settings.
It's quite easy to loose track of the consistency of settings for multi builds with optional file overrides and is an issue I've come across on other IDEs.
In fact has any IDE got a good solution for this?
Last Edit: May 14, 2014, 12:03:56 pm by euzer
Logged
gmb42
Frequent Contributor
Country:
Reply #5 on:
May 14, 2014, 11:16:15 am »
I've used XML diff tools in the past, can't remember what, a quick Google search turns up
DiffXML
Logged
engineer_in_shorts
Regular Contributor
Country:
Reply #6 on:
May 16, 2014, 08:39:09 am »
Not that i am aware of but sounds like a good idea to diff the xml.
I just found out that you can pass the project file in command line, kinda like a make file, if you need to build from command line. Maybe i am a bit behind the times!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
