Author Topic: STM32CubeID problem  (Read 5969 times)
Offline ElectrinTopic starter
  • Country: cz
STM32CubeID problem
« on: June 04, 2019, 08:56:45 am »
Hi everybody,
I have downloaded STM32CubeIDE recently to test it and compare with Atollic Studio. If I wanted to create first project with help of Device Configuration Tool Code Generation, this fail was appeared: "Error downloading the following files: stm32cube_fw_IO_v1110.zip (Target directory already exists)"
I tried to change FW installation repository and launch program as admin, however mentioned problem still stays unresolved.
Does someone have an idea to fix this situation? What I do wrong?
Thank you very much for your advices  :)
Offline fonak
Re: STM32CubeID problem
« Reply #1 on: June 04, 2019, 04:58:45 pm »
hello
1. Close CubeMX
2. go to the folder C: \ Users \ ....UserName....\ STM32Cube \ Repository
and extract the zip archive manually, e.g. stm32cube_fw_f4_v1240.zip
3. In the Repository folder should appear a folder with the name STM32Cube_FW_F4_V1.24.1
4. The same applies to other types, eg F1 F2 F4 or H7
