Electronics => Microcontrollers => Topic started by: mozcelikors on March 21, 2013, 11:03:51 am
Hi guys,
I'm an Electrical & Electronics Engineering student. For a long time I've been working with Arduino, and I was able to achieve a couple of projects about robotics, networking, and sensor readings. In the school, we are taught VHDL, C; and I was able to improve my skills of programming for -say- 5 or 6 years by developing apps and softwares. So, I guess I have what it takes to start FPGA's.
Developing projects with Arduino is easy, however I want to do more engineering stuff, so I decided to get an FPGA. ( or DSP board, whatever you guys recommend ). I've checked the stuff available and shipment options, and for a starter I liked these boards that I want you to review and tell me one to buy. Here they are:
Altera DE0 ( Cyclone III )
Altera DE0-Nano (Cyclone IV )
Xilinx Basys2 100K Gates
If you want to recommend another board within the same price range (up to 150$) or another developement process, please do it. I'm open for suggestions.
Thanks.
I've got a DE0-Nano board which I used as an intro into the FPGA world (Using Verilog). I found it pretty easy to get started with, really my only complaint was that you can't use the built in ByteBlaster programmer to program other devices, so if you were to design your own pcb with an Altera device on it, you wouldn't be able to use the DE0-Nano board to program it. Having said that, USB Byteblaster programmer clones are readilly available on ebay for not much.
You can try LCMXO2-1200ZE-P1-EVN
It's development/evaluation board from Lattice, which contains 1280LUTs and has internal config memory. It has some peripherals, but a rather modest set. It costs 161 PLN in Poland, so equivalent to $50 (probably much cheaper elsewhere). I's say it's a good price for an FPGA board.
plus the fact that Lattice devices are cheaper than Xilinx or Altera for the same class of device of course.
To Codemonkey,
I really appreciate your opinion, I dont mind pcb designs for now. I'm just a beginner to this. How about DE0? Is it better than DE0-Nano? I really liked the interface outputs ( I mean PS2, VGA,.. ) on the DE0 board.
To poorchava,
Well, I dont think they have Lattice FPGA boards here in Turkey. I was planning to buy Altera from the website with international delivery FedEx. I dont know is it trusted or not. I would be much appreciated if you provide me a link that has international shipment.
The DE0 Nano has a much more powerful FPGA (Cyclone IV) than the DE0; however, the DE0 has more I/O and configuration options. If you already have a project made up that you want to encorporate an FPGA into (without having to worry about BGA soldering, power supply conditioning, netlists etc) then the Nano is a good bet for you... it is smaller and can plug right into whatever you're doing. On the other hand, if you want a fully featured board to experiment with and learn about FPGA's in general, then I would recommend the DE0 (or actually a digilent Xilinx board)
Just to make it a bit more complicated: eBay auction: #310620854594
Depending on how soon you need a board, here is another option that has a fairly good price: http://kck.st/UNVcNE (http://kck.st/UNVcNE)
It's a new board built around a Spartan 6 (9k cells), should be shipping in a month or two (assuming no major delays).
There are bigger chips out there, but it's hard to beat $65 shipped ($70 for overseas) for a starter board.
Just pointing out the obvious though - this is a Kickstarter projects. Design/Tech projects are notorious for delays, especially for popular projects which greatly exceed their original target goals (this one is over 10x their goal with 2 days left in the campaign). So there is a very real risk with what you actually get out of it.
Get the DE0
Avoid the xilinx boards unless you prefer bludgeoning your genitalia with blunt objects. The hardware aint too bad (though they cut corners whereever possible -- see gimped DCM vs full PLL) the development software is the real killer
I really thank everyone that shared their opinion.
Thank you for your input. It's very helpful. Actually now I'm too far to building pcb projects with FPGAs, because I have 3 Arduino MEGA's that helps me build pretty much everything I want. I'm buying the FPGA board just for learning purpose, introducing the device and VHDL programming practice. But in the future of course, I want to do somethings with that board. Is the hardware difference between DE0 and DE0-Nano noticable? Or is it just noticable in high leveled apps?
Another question for now? Xilinx or Altera? Does the IDE's differ much?
Get the DE0
Could you elaborate on this a little bit? I am just getting started with the Xilinx ISE environment, and I can't say that I am thrilled with it. The installation process was exceedingly painful, and the UI flow just seems bizarre (I have been going through their web tutorial project where you build a stopwatch). I assumed my hiccups were due to just being new to FPGA toolchains in general - but am I putting myself at an unnecessary disadvantage by using a Xilinx chip (and ISE)?
To poorchava,
I'm pretty sure Farnell operates in Turkey, and they have quite a broad range of Lattice chips.
Oh yes, but people tell me to avoid Farnell if i can. I dont know why though.
If you're already comfortable with hooking things up to digital I/O pins then you could do worse than one of these:
http://www.ebay.co.uk/itm/Altera-CycloneII-EP2C5T144-FPGA-Board-USB-Blaster-JTAG-/190501213198?pt=LH_DefaultDomain_0&hash=item2c5ac1d40e (http://www.ebay.co.uk/itm/Altera-CycloneII-EP2C5T144-FPGA-Board-USB-Blaster-JTAG-/190501213198?pt=LH_DefaultDomain_0&hash=item2c5ac1d40e)
It's about as simple as development boards come - just the chip on a board with a voltage regulator, a configuration EEPROM, one button, and a 50 MHz crystal oscillator. There's no cheaper way to take your first steps into learning VHDL, and the USB programming adapter that's included is a general purpose tool which will work with any board you ever design with an Altera FPGA in it. Download the free version of Quartus from Altera's web site and you're ready to go.
Be warned: the pinout diagram on the sticker is wrong - nCS and nCE are swapped, if I remember correctly. Otherwise it's a perfectly functional clone of the official USB Blaster cable; the hardware itself is correct even though the picture is wrong.
Thats weird. I order from Farnell all the time. For small quantities they are expensive (ofcourse) but for larger quantities they can be just as cheap as a distributor.
Get the DE0
***Rant warning*****
I work extensively with Xilinx and ISE,
I really love the demo boards and the chips, they are usually designed to be sturdy, but I have to say that many of the comments related to how bad the tools are, are just too kind....
The tools are bad, fortunately Xilinx does not design Silicon the same way it designs tools, if they did they would be dead a long time ago.
Hi Mozcelikors,
I would to suggest the EPT-570-AP from www.earthpeopletechnology.com (http://www.earthpeopletechnology.com) It is a complete CPLD development board that includes a USB JTAG programmer. It also provides an SDK which allows you to create interactive USB communications from a Windows PC to the CPLD. The SDK hides all of the USB driver stuff. The CPLD comes with libraries to easily send and recieve USB transfers.
It is very cheap at $55.00. And it comes with a user manual that has step by step instructions on how to create projects on both the CPLD and the PC.
You could download Mike Fields getting started book
http://forum.gadgetfactory.net/index.php?/page/articles.html/_/papilio/logicstart-megawing/intro-to-spartan-fpga-ebook-r34 (http://forum.gadgetfactory.net/index.php?/page/articles.html/_/papilio/logicstart-megawing/intro-to-spartan-fpga-ebook-r34)
then either just work through the exercises using the Xilinx ISE and then optionally buy either the Gadget Factory Papilio board or the Digilent Basys board to run them on.
Both use a Xilinx spartan 3. I got the papilio with logicstart addition for less that $100.
I have a Basys 2 FPGA board with 250K gates and I love it. It has a selectable 25 - 50 - 100MHz clock (if you need it because of the VGA and PS2 ports, you will need for a good image resolution the 100MHz) and it has a socket for user clock which can be up to 300MHz according to the spartan's datasheet. It features 16 I/Os, VGA output, PS2 port, 8 slide switches, 8 LEDs, 4 debounced push buttons, 4x 7 segment display, about 1hz clk, 20-50-100MHz clk, user clock socket, program memory, mini b USB, 2 pins for battery power, on/off switch, and of course the spartan 3e chip.
The programming platform is ISE Web Pack, which is free, you just have to register download, install, and make a free licence, I can make a video to show you how to get started with it, if you use windows, then the adept provided by the digilent can be used to upload very easily the program, if you use linux, than it's a little more complicated because you must have to learn to use the xilinx uploader, which is the impact,(included in ise web pack), and since the Basys board is digilent board not xilinx you have to set it... (it took me a while to learn to use it on linux, but a bad tool.)
You can use Verilog, VHDL and Schematic design. (I use schematic, and love to make multiple A0 sized schematic designs... :D, didn't learned the other 2 yet, but perhaps later...)
Digilent documentation is very poor, but the board is pretty powerful... The only thing I'm not satisfied with is that there is only 16 I/O ports, but if you can live with that, than I say that for video processing it's more powerfull then the othr boards... There is one thing that I like the most in that board... I like that all I/O ports are at the same side, this way if you just put the pins on your custom board in a row in 4 groups of 6 pin with 3 - 3 pin space, you can attach the digilent board to your own in a vertical direction like PCI on the motherboard... :D
As for SD slot, that's pretty easy to make, so I would not worry about that.
By default it runs at 50MHz, and comes with no jumper not even pins to select clock speed, just holes, but you can easily solder in some pins and put a jumper for the frequency to be selectable. It works well I tried it.
if you are a student you can use some student discounts that Xilinx or Altera provide for their development boards. I have not checked other manufactures.
Yep,
Digilent.com offer student discounts... BUT ISE is the problem, once the license expires some of the boards are useless because they contain parts that are not part of the ISEweb edition.
Yep,
ISE Webpack does not accomplish your required task?
ISE Web pack is good enough for a start... you not gonna use half of it... :P You need the compiler which is the ISE itself which is free, and you need impact to upload your program if you work on linux, which is also free (I didn't tryed on mac, only on windows7 and ubuntu.)
What about the demo version of the commercial versions?
Xilinx FPGA development boards from the more well-known companies (Digilent, Avnet, Xilinx themselves) tend to come with non-expiring device-locked ISE licenses these days. The device locking is actually for a specific FPGA model - not the computer or dev board itself.
