It turned out the firmware programmer decided to use a GPIO interrupt which kept firing when the pin was half way a logic level Worst of all he and the R&D manager refused to believe me that doing that was the stupidest thing to do -ever-. The company nearly went under from lawsuits due to the product not working properly and here they where telling me they where doing a good job and GPIO interrupts where meant for buttons
Well seems like there are three issues here.
1.Signal integrity/circuit-design.
2.Debouncing
3.Interrupt handling
1. This is an issue, either way. It could potentially be alleviated or fixed, despite shoddy signal, with deboucing. This holds equally true in either method. Only with ISR, you can do this in the background with timers instead of stopping main code loop.
2. Debouncing: This can be achieved in either method
3. Interrupt handling: You could set up the GPIO interrupt to timeout after a switch is detected, in addition to or as part of the debouncing, using a timer interrupt. Thus effectively giving it a minimum period, similar to polling. Could be something like GPIO interrupt triggered, the ISR will turn off GPIO interrupt, turn on timer0 interrupt, check state of input pin in after X time has passed, a number of times. After switch is detected, set a flag and/or perform immediate task. Continue timer interrupt polling until input returns to resting state, then initiate timer interrupt to turn the GPIO interrupt back on after X time has passed. If debouncing fails, then initiate timer to turn GPIO interrupt back on after X time has passed.
If you can trust a WDT to keep the MCU running in mission critical situations, seems like other interrupts can be relied upon if implemented correctly. Complexity of proofing not withstanding.
If you told me that, I wouldn't believe it. Button interrupt is very useful for waking a micro from sleep via user input, and quite commonly used for such task. I would fix the code (and the circuit). But of course this is a doorbell, not a manned vehicle control system. Seems like problem 1 is the main issue. The other example of randomly performing a super long calculation within the ISR (and not turning off that particular interrupt during timing sensitive task) is super noob. Perhaps could have just set a flag in the ISR which results in the calculation somewhere in the main program loop, so that it could be interrupted, itself.
I would have thought that timer interrupts, in particular, would be quite useful in mission critical applications. The WDT being one perfectly good and valid example, IMO. WDT is barely more, really, than a timer interrupt with a RESET instruction. It might run off a different clock source, of course, which is the "barely more" part. It might also set a flag that can be detected after RESET, but that's still nothing you couldn't do with a regular timer interrupt.
there is no such thing as an interrupt between arbitrary machine instructions on an FPGA.
You can turn interrupts on/off in the software before starting code blocks that cannot be interrupted. I suppose this doesn't help so much in C, where finding a safe place to enable interrupts might be more challenging without a very deep understanding (or trust) of the compiler and libraries.
So far, the main reason to not use interrupts in mission critical apps seems to be human error. Surely this is a good enough reason. But it also seems like using interrupts can greatly simplify code in certain situations. Perhaps sometimes enough so that it makes things easier to proof? Heck, some programs could be 99% ISR and 1% code loop. This could be the easiest way to write a given program.
There's my 2 cents. Now I'm really broke.
